Honda issued a Field Fix Service Bulletin dated 12/8/1976 "CB750 Clutch Noise Update". It's posted up here somewhere. They came up with 'the fix' in response to the noisy clutches. They took a 75 - 79 ?? GL double metal plate and added it to the middle of the clutch pack in place of 1 stock metal plate, the 4th from the bottom of the stack, and removed one fiber plate, the one from the bottom of the stack, to make room. The 'permanent' fix in late '76 was to make a slightly longer basket to accommodate all the fibers AND the double metal disc. You can swap out all the parts. Works nicely. It gives you 2 options for a noisy clutch or you can keep the original set up. If you go with using a 77/78 clutch set up you also need to get a 77/78 clutch cover or modify your stock one by grinding down the inner ridges.
