Author Topic: Turn signal wiring cb500kO  (Read 689 times)
Offline jamesbekman
« on: April 12, 2016, 01:55:36 PM »
Hi,
Does anyone know off hand the wiring in the headlamp bucket for the turn signals?  I'm having a few problems referencing the wiring diagram.  When connecting is it all same color to same color?  Everything else on the bike is working properly (I do not have the headlight hooked up to test at the moment but will be doing so shortly.  The turn singal light in the "dash" works fine.  The front turn signals are not effected by the turn signal switch at all.  Rear lights have never worked and am running out to get some bulbs to verify.
James
Offline jamesbekman
Re: Turn signal wiring cb500kO
« Reply #1 on: April 12, 2016, 06:43:12 PM »
Figured it out.  Had black wires that were coming out of the front turn signals but they had a color code on them at the bullet connectors.  Had to change the flasher after plugging in the wires in the correct spot.  Left side is orange and right side is light blue for anyone needing to reference in the future.  I have a follow up question I will be starting a new thread on in regards to headlights not being bright enough and a brown wire not connected to anything if I cannot find it in the diagram.
