Author Topic: Starter clutch spring specs  (Read 724 times)
Offline eigenvector
« on: April 12, 2016, 06:32:42 PM »
Does anyone have the specs that go with Honda's starter clutch springs?
Need to replace the ones in my Nighthawk and I can't find any guidance as to what they're supposed to be.
I've measured them of course, but spring rate is totally beyond me - and it matters
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Starter clutch spring specs
« Reply #1 on: April 12, 2016, 06:51:14 PM »
They are all soft. Just source a new set. Would be nice if they cross referenced with the 750's??
Offline eigenvector
« Reply #2 on: April 12, 2016, 07:45:50 PM »
It does cross-reference.  Spring hasn't changed since the later model SOHC 750's and is still valid for all the 80's models.
The Nighthawk is a special breed.  The starter clutch for it was valid for 3 years only, and it wasn't rebuildable.  I actually had to drill out the pins they used to secure the cover.  But inside it was the same old crummy design that has been around forever.
I'm looking for springs that are bit better than what Honda's selling because I really don't want to crack the crankcase again.
Rob
1977 CB550K
1983 VF750S Sabre
Offline eigenvector
« Reply #3 on: April 12, 2016, 09:12:25 PM »
Well I put in an order for a couple options.  If they don't pan out I can fall back and order OEM from Powersedge for the CB650.
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #4 on: April 12, 2016, 09:40:13 PM »
Is the starter gear similar to the 750? I replaced the rollers, springs and caps. The roller surface on the gear was really bad, unround, so I found a better one and used that also. It seems to work great now. No more slipping out or not catching.
