Author Topic: Fuses  (Read 1443 times)
Offline 550Resto
Fuses
« on: April 15, 2016, 06:16:04 AM »
Hey all, I've been trying to get my 550 up and running and was trying to diagnose a headlight issue. The headlight doesn't come on when the key is in the on position. I began to look at the fuses and 2 of the the 3 are toast. I've got some on order, but wanted to see if automotive fuses can be used from Napa? Also need a flasher relay which I've searched and seems like a relay from auto parts store is acceptable. Any help appreciated.
Re: Fuses
« Reply #1 on: April 15, 2016, 06:57:42 AM »
I've bought fuses at an auto parts store but they need to be the correct length.
Our bikes take a slight shorter length than most commonly used auto fuses.
While you are at it, clean the fuse holder clips with some emery cloth.
Offline mrfish2
  • I might be a
Re: Fuses
« Reply #2 on: April 15, 2016, 07:11:19 AM »
Our bikes use the 1" fuses, while most auto parts stores sell 1.25" fuses (ask me how I figured this out  ::) )
Easiest thing to do is buy a modern blade fuse panel from Hondman. It's plug and play and takes the hassle out of the 40 year old fuse box.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Fuses
« Reply #3 on: April 15, 2016, 07:15:40 AM »
Or roll your own fuse block! More fun that way.
--Evan
1975 CB750K "Rhonda"
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=cq1h57uka82srffvampshk3uq1&/topic,60973.0.html
Re: Fuses
« Reply #4 on: April 15, 2016, 07:26:03 AM »
yes thek the old fuse holder..for korosion and heat damage.....often you are better vith a nev blade fuse type .
.you can reuse the viring ,,just solder,,or screv the vires on the nev fuseblock..drill a new hole in the bike ,,,reuse the one old hole..and bolt it on..
i hate all this v-w.... vords
Offline Mantree
Re: Fuses
« Reply #5 on: April 15, 2016, 05:06:29 PM »
I have a fuse block from Amazon
Sent from my ME302KL using Tapatalk
Offline 550Resto
Re: Fuses
« Reply #6 on: April 15, 2016, 05:52:27 PM »
What all does the main fuse supply power to? Haven't had a chance to chase wires on the wiring diagram. Just wondering if the bike would run without it.
Offline 550Resto
Re: Fuses
« Reply #7 on: April 15, 2016, 06:38:31 PM »
Is the starter connected to the main fuse?
Re: Fuses
« Reply #8 on: April 15, 2016, 07:35:51 PM »
But not "plug & play", right?
Offline Mantree
Re: Fuses
« Reply #9 on: April 15, 2016, 08:12:02 PM »
No but you just clip off the pigtail from the old fuse box and attach them to the new fuse box
Sent from my SM-G900V using Tapatalk
Re: Fuses
« Reply #10 on: April 15, 2016, 09:24:17 PM »
Not the high current side of the starter. The coil that operates the starter solenoid is powered from the main fuse.
