Author Topic: 750 seat trim  (Read 1186 times)
Offline Johnie
750 seat trim
« on: April 15, 2016, 06:51:26 AM »
Before I buy...have any of you tried this seat trim and how do you like it? A bit pricey at $70, but need to be sure the quality and original style is there.
http://www.hvccycle.net/reproduction-molded-chrome-seat-trim/
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline el pachuco
Re: 750 seat trim
« Reply #1 on: April 15, 2016, 06:58:24 AM »
scouring the web last night for CB750 parts, I ran across some new seat trim for $8, I think. That's crazy cheap.
Offline przjohn
Re: 750 seat trim
« Reply #2 on: April 15, 2016, 07:02:49 AM »
Have not bought the trim, (Yeah, I know, that helps immensely  ::) ) but have bought a lot of 2 stroke stuff from HVC and they are a top notch outfit and have never had a problem with the quality of their stuff.
Re: 750 seat trim
« Reply #3 on: April 15, 2016, 07:03:38 AM »
I got mine from Sirius Consolidated,  it was cheaper, not sure how authentic it looks.
DH
Re: 750 seat trim
« Reply #4 on: April 15, 2016, 10:10:38 AM »
john I believe member "oldhat" was mentioning that stuff a while back, you might give him a PM.
Offline Johnie
Re: 750 seat trim
« Reply #5 on: April 15, 2016, 10:41:46 AM »
Checked out "oldhat" and he has not been active since June 2014. I did send a message to "oldhat45" maybe he is the member. Thanks for the tip.
Oshkosh, WI  USA
Offline Johnie
Re: 750 seat trim
« Reply #6 on: April 15, 2016, 10:44:10 AM »
By the way I am fine with gluing it on as the PO broke off all the OEM tabs that held the other in place. Here is the cheaper one $8...a lot cheaper than the $70 one, but not sure if this is will stand up or crack.
http://www.ebay.com/itm/120934462094?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
« Last Edit: April 15, 2016, 10:51:48 AM by Johnie »
Oshkosh, WI  USA
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
Re: 750 seat trim
« Reply #7 on: April 15, 2016, 06:50:16 PM »
Johnie, et. al.,
Yep the HVC part number HVC-SEATTRIM-MOLD
is the one I bought.  And Yes It's Pricey at $78.xx, but it is Identical to the original seat trim.
HVC sometimes takes a while to ship this part, I guess cause they don't sell many.  LOL
Just need to make sure you leave a little space for the tacks or alligator strips.
Also, it does NOT need Glue to put it on and keep it there.
Charlie
Offline jonda500
Re: 750 seat trim
« Reply #8 on: April 15, 2016, 07:59:38 PM »
That $70 trim is for the seat cover type that originally came with the chrome trim being part of the seat cover. The pan for this type of seat cover doesn't have alligator teeth that poke through the vinyl and fold over, it has large tabs that fold over and catch on the ledge that the $70 chrome trim has. If you are using alligator teeth strips the $8 trim is gonna work just as well!
John
A starter clutch thread:
Offline Johnie
Re: 750 seat trim
« Reply #9 on: May 29, 2016, 05:39:09 PM »
So I went with the HVCycle trim and it really worked and looks good. Since the PO broke off all the clips I used JB Weld to hold it in place. Sure it was pricey, but looks so good I am really happy with how it turned out on this K3.
Oshkosh, WI  USA
Offline oldhatt45
Re: 750 seat trim
« Reply #10 on: June 14, 2016, 04:43:44 AM »
Johnie,
Glad to hear it worked out for you.
But, it didn't happen without pictures :)
Charlie
Offline Johnie
Re: 750 seat trim
« Reply #11 on: June 14, 2016, 06:10:02 AM »
Here is the seat trim pic :)  It for sure is a quality piece compared to the cheap stuff.
« Last Edit: June 14, 2016, 06:11:38 AM by Johnie »
Oshkosh, WI  USA
Offline oldhatt45
Re: 750 seat trim
« Reply #12 on: June 14, 2016, 06:35:51 AM »
Johnie
LOOKS GOOD!!!!!
Can you take a picture of the underside of the seat?????
That would help others to see how it went together.
Nice Job!!!!!
Charlie
Offline Johnie
Re: 750 seat trim
« Reply #13 on: June 14, 2016, 07:04:57 AM »
Underside of seat and close up of trim.
Oshkosh, WI  USA
