Author Topic: Front end shortening and stiffening for drag racing  (Read 1650 times)
Offline dragracer
  • CB750F Dragbike
« on: April 19, 2016, 11:39:02 AM »
Found this on the Hondachopper site. Thought I'd share here since I sometimes have people asked me how to perform this task.
The main thing I would not do, is to cut the spring as they show. Leave it full length if you want a stiff front end. It'll be tough to get the cap back on but you'll be pleased with the lack of travel. Instead of the bronze bushings, I sometimes use CPVC tubing or inner valves springs from a Zuk head. You can lower it as much as you want by the length of the sleeve you choose on the damper.
http://www.hondachopper.com/garage/shortening_forks/shortening_forks.html
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Front end shortening and stiffening for drag racing
« Reply #1 on: April 19, 2016, 11:59:22 AM »
That is exactly how I plan to do it. By leaving the spring uncut there should be no need for straps. I even have an idea to help get the cap back on and will post it here should it prove to be successful. If the cap goes flying and strikes me in the head then I might not post that!  :o  ;)  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline TurboD
« Reply #2 on: April 19, 2016, 12:42:59 PM »
I normally use aluminum tubing for the spacers and retain the original small rebound springs for a little cushion. I will cut the springs, but I don't cut as much off as the spacers. this will help to stiffen up the front.
« Reply #3 on: April 19, 2016, 12:45:31 PM »
The tutorial in the link to the Hondachopper site may be using an early model fork. The piston spring was used in later models.
TAMTF...
Wilbur
Projects:
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: April 19, 2016, 01:13:26 PM »
The concept is the sane nevertheless. Again, the goal is not only to lower, but to stiffen and reduce travel. Its the extension of the tubes on hard launch that hurt any bike use for racing. Pulling the tubes up in the triples does absolutely nothing to help with fork extension, it only lowers the bike but the mush us still there.  Glad you decided to do it the right way Wilbur. Just be careful of the cap. Eye protection is a must. And maybe a nutt cup. Lol.
Offline dragracer
  • CB750F Dragbike
« Reply #5 on: April 19, 2016, 01:15:17 PM »
Heck, I even used a set of old handle bars one time to make spacers. Whatever works and is available at the time.
Offline TurboD
« Reply #6 on: April 19, 2016, 01:16:13 PM »
I'm sure that is the case. I like having the spring so that you don't get that hard solid bump when the fork tops out.
Offline TurboD
« Reply #7 on: April 19, 2016, 01:17:01 PM »
Haha I've used copper pipe. Lol
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #8 on: April 19, 2016, 01:20:35 PM »
yeah, broom sticks work too  ;D
Offline dragracer
  • CB750F Dragbike
« Reply #9 on: April 19, 2016, 01:25:29 PM »
[/quot
Uhhhhh, I'll pass on those. Hahaha.
