Author Topic: Need longer swingarm bolt and engine mount bolt for rearset brackets. Any ideas?  (Read 897 times)
Offline palo86
I have a 75 CB550F and am trying to make the rearset brackets I purchased from Cognito Moto work.  The main problem I'm running into is that the swingarm/engine mount bolts are too short to mount the brackets.
Does anyone know where I can source longer bolts?
Thanks!
Chris
« Last Edit: April 22, 2016, 11:06:40 AM by palo86 »
Offline slikwilli420
  • Master of Disaster
A bolt that long is going to be tough. Best bet is to make it. I have done all of my engine hanger bolts this way. Have a shop thread the ends of some steel or SS rod and weld a nut to one end making a long bolt.
 Check length of the 77/78 bolts much longer but may be bigger diameter... what size are you  talking...
 the other alernative, order shafting from McMaster, and thread the ends..
« Last Edit: April 22, 2016, 08:32:29 PM by 754 »
Offline palo86
Thanks Slik and 754.  I was actually able to make it work.  I modified the bracket on the clutch side to allow the bolt seat deeper.  Gave me enough clearance to get the nuts threaded on.
Chris
« Last Edit: April 25, 2016, 02:44:45 PM by palo86 »
Offline mrfish2
  • I might be a
Thanks Slik and 754.  I was actually able to make it work.  I modified the bracket on the clutch side to allow the bolt seat deeper.  Gave me enough clearance to the nuts threaded on.
Chris
Will you post up some pics of what you did? I'll eventually run into this as well if I can ever get my build started.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline alacrity
  • Ride, Optimize, Repeat
Yeah it's ez to get stainless or plain steel rod of any diameter and then have threads turned on the ends.  That's the solution I think.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
