Author Topic: Open style exhaust popping on decel  (Read 871 times)
Offline cuz
« on: April 24, 2016, 01:45:26 PM »
I have searched this topic and just wanted a couple last opinions.  I have a cb750k7, stock airbox, 4-1 cycle-x exhaust with stainless silencer, stock jetting, carbs cleaned, sync and timing complete.  On my first couple of test rides I notice that the exhaust will pop a bit on deceleration.  It does not pop at idle and the popping is pretty much zero when you blip the throttle while stationary.  The plugs are a bit rich looking but in the normal zone I believe.
My question is, can I expect a bit of popping on deceleration with such an open style 4-1 system?  There is zero baffle in the stainless "silencer"  so it's pretty much straight piped as far as I'm concerned.  The exhaust note is not obnoxiously loud either and has a throaty growl on acceleration.  I don't mind the popping... kind of sounds like a rally car a bit, I just want to make sure the popping isn't a sign of something else as long as the other signs of issues like plug color are fine.
Re: Open style exhaust popping on decel
« Reply #1 on: April 24, 2016, 01:47:17 PM »
If you have an airleak at the pipe to head joint, it will do what your is doing.
Offline Mantree
« Reply #2 on: April 24, 2016, 01:50:26 PM »
Yes you can the baffles give time for the gasses to cool a and expand before hitting the cool O2 ditch air my bike with open 4into2 pipes pops on deceleration as dose my straight pipe truck
Sent from my ME302KL using Tapatalk
« Reply #3 on: April 24, 2016, 09:09:45 PM »
what color are your plugs?
