Author Topic: Painting engine questions  (Read 4201 times)
Offline SKOL
« on: April 27, 2016, 04:18:57 AM »
I have a few questions when it comes to painting my engine. I'm going to leave the covers polished, just re-paint the motor a nice silver. The engine is complete torn apart at the momemnt. Should I repaint piece by piece, i.e., tape off the bottom case and paint it, tape off the top and paint it, etc. or just clean everything, soda blast it, and wait until it is all assembled and just tape off the covers? What do you guys think? Anyone had good success either way? Also I've heard mixed reviews about VHT, anyone have any other tried and tested engine paint they use religiously? Thanks
Re: Painting engine questions
« Reply #1 on: April 27, 2016, 04:50:30 AM »
I've used VHT with good results.  Recently painted my fully assembled K3 motor, and would suggest that to prevent paint damage during assembly, but can do either way.
« Reply #2 on: April 27, 2016, 04:52:10 AM »
It was done both ways, I prefer to paint it a piece at a time - you can bake the part to harden the paint.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #3 on: April 27, 2016, 07:03:30 AM »
Agree with all - I've had great success with VHT, but you MUST bake it for durability. If however you don't want to worry about it, send it to me and I'll vapor blast it :-)
I have a motorcycle problem.
Offline NobleHops
« Reply #4 on: April 27, 2016, 07:05:06 AM »
Here's an excellent how-to on the engine painting process:
http://www.cbxclub.com/forum/viewforum.php?f=27
« Reply #5 on: April 27, 2016, 07:11:22 AM »
+1
Paint and bake individually.
Its all in the prep, for rattle can paint to last.  blast, pressure wash, acetone wipe down.
Offline NobleHops
« Reply #6 on: April 27, 2016, 09:34:27 AM »
+1
I've done this set of steps, worked great, but some kind of phosphoric acid etch (alodine, alumaprep) is a skosh better yet. Wear gloves while cleaning, keep your grubby fingerprints off of the parts. :-)
Offline przjohn
« Reply #7 on: April 27, 2016, 10:07:03 AM »
Another vote for painting by pieces and baking. I have had great luck with VHT paint color "Universal Aluminum" Baking is a very important step and should not be omitted.
Offline SKOL
« Reply #8 on: April 27, 2016, 10:19:37 AM »
+1
After blasting, pressure washing, and acetone wipe down. When it comes to getting to cases ready for primer, should I use a soft scotchbrite pad with alodine or alumaprep to etch the cases slightly, or just rub it on? I know I want to make the surface slightly rough for the primer to adhere to nicely.
« Last Edit: April 27, 2016, 10:21:09 AM by nalexandrou »
Offline gtmdriver
« Reply #9 on: April 27, 2016, 11:10:08 AM »
I used POR15 engine enamel on my Moto Guzzi cases.
I painted it almost fully assembled.
Brushing the paint left streaks so I thinned it with White Spirit and sprayed it. No baking needed.
It has been on for 8 years now and is definitely petrol proof.
Offline Ilja
« Reply #10 on: April 27, 2016, 11:15:17 AM »
Just be carefull baking the cylinders. Did it once and all the sleeves came out under the weight of the cylinders during baking. Thats a hone job after reinstalling.
You can also bake it by driving... but I think the paint will be slightly less though.
« Last Edit: April 27, 2016, 11:16:54 AM by Ilja »
« Reply #11 on: April 27, 2016, 11:19:31 AM »
+1
your blasting will give the surface enough texture to hold paint.  I skipped etching and priming..
I used about a dozen rags and 2 qts of acetone to do my whole engine.
Wiped till all surfaces came clean, then went right to paint.  Baked 30 min @ 250
Offline Rocky2010
  • Live in Strayla
« Reply #12 on: April 27, 2016, 07:00:21 PM »
Im at the stage of stripping my engine I think I will get it Hydroblasted and leave it with that finish rather than paint the engine with silver paint.
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline NobleHops
« Reply #13 on: April 27, 2016, 08:39:32 PM »
Send you a PM, but in Australia, (Sydney) you should consider Dave Mac - he is excellent at this work and just a great guy.
vapourblasting@yahoo.com.au
« Last Edit: April 27, 2016, 08:42:00 PM by NobleHops »
Offline koendd
« Reply #14 on: April 28, 2016, 07:22:51 AM »
you can, but I've had a carb leaking (just forgot to thighten a drain screw on my K2) and dripped overnight on my newly painted engine...
I could peal the paint of.  >:(
Luckily you can repaint it and you won't notice it afterwards. Blends in perfect with allready painted area's...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline NobleHops
« Reply #15 on: April 28, 2016, 09:51:47 AM »
Did you bake this engine? I've spilled gas on mine and no problem.
Offline koendd
« Reply #16 on: April 28, 2016, 01:30:22 PM »
nope,
engine ran perfect, just didn't look good...
Couldn't tear it apart just to paint it.
It'll bake while riding, just have to be carefull not to spill gas etc before you can ride a for a while..
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline adamrdiamond
« Reply #17 on: May 11, 2016, 11:06:30 PM »
Did you cover all the screws and bolts before painting or pull them all of?
Offline rocs
« Reply #18 on: May 12, 2016, 04:01:00 AM »
I think i may leave my screws on and paint. Once cured i may take them off and polish them.
1975 CB550k's
Offline koendd
« Reply #19 on: May 12, 2016, 01:48:19 PM »
yep, don't take them off till after paint.
Just remove and replace/polisch them one by one after the engine is dry ;)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
