Support the site. Your contributions keep this site running.
Replaced float hardware w/ sockets (can change jets w/o removing!)
Quote from: sammermpc on June 21, 2016, 05:22:15 AMReplaced float hardware w/ sockets (can change jets w/o removing!)What do you mean by this?
I think he means he replaced the float bowl screws with allen heads.
Thought I'd update here, just for the other folks who are inevitably going to run into this common set of problems — after everything was said and done, as many others have, replacing the pilot jets with Keihin #40s made the difference. Swapped them in, and boom — hanging idle was gone. Embarrassingly, I don't think I actually cleaned my OEM #40 pilots well, despite trying many times. I did not realize there was a hole at the end of jet, which was always clogged, and causing it to run lean on the pilot circuit. When I finally got a new set, I realized my mistake. Of course, in this process, I: Replaced intake, output boots & manifold o-ringsReplaced points & points plateTrimmed advancer springs 1/2 turnSet valves & timingVac sync'dReplaced float hardware w/ sockets (can change jets w/o removing!)And yeah, I think I probably could've skipped all of that by just replacing the pilots! All the same, so glad to get it running. Took a beautiful ride last weekend. Here she is in full-regalia (looking for a windscreen):
