I was just wondering what gasket sets you guys are using and having good luck with. I just went through the top end on my 550 and used an emgo gasket kit ( yes yes i know never use cheap parts ) but i didnt evan know if the engine was good so i was trying to get it together for the lowest amount possible to see if the motor was good. Well ive got it going and in the end of the head where the caps that hold the rocker arm shafts in the orings that go on are leaking on one side, there the new ones that came with the kit so now im questioning all the other orings that came with the kit, valve seals too. Im thinking there not going to last long. So i want to pull it back apart and put some good quality gaskets and orings in now that i know it runs and drives like it should. My other question is whats the fix on a stuck clutch? Every time i let it sit for a day or two the clutch sticks and i have to put in 5th gear and rock it to break it free, let it sit for a few days it does it agsin. Should i pull the clutch pack and sand the glaze off
