Author Topic: Refinishing Original Bolts (Vinegar, Wire Wheel, and ????)  (Read 9407 times)
Offline edwardmorris
  • Youngish
Re: Refinishing Original Bolts (Vinegar, Wire Wheel, and ????)
« Reply #50 on: May 05, 2016, 03:01:38 PM »
This is what I ordered. Only ones missing are the small cam chain tension adjusting screw (this is special, reuse old one or buy new from Honda) and the main bearing ones (use APE studs). Someone double check this please.
ARP SS Flange
6x30  x 8
6x40  x 10
6x50  x 4
6x55  x 4
6x80  x 2
6x100 x 7
8x55  x 2
10x80 x 1
Offline mystic_1
  • 1970 CB750K
« Reply #51 on: May 05, 2016, 06:39:41 PM »
Final question... anybody know what the original case bolts are made of? Just regular old steel that has been zinc plated?
They're "regular old steel" as in not stainless steel, not aluminum, not titanium, not neutronium, etc.
mystic_1
- John Augustus Shedd
« Reply #52 on: May 05, 2016, 06:54:05 PM »
just use nail polish on them after install , if you are just wire wheeling them..
Offline SKOL
« Reply #53 on: May 06, 2016, 07:49:18 AM »
ARP SS Flange
6x30  x 8
6x40  x 10
6x50  x 4
6x55  x 4
6x80  x 2
6x100 x 7
8x55  x 2
10x80 x 1
I've never installed bearing or cylinder studs before, from the pictures I've seen they are rods, threaded on both ends. I understand the install procedure for cylinder studs, but how does that work when installing the bearing studs if there is no bolt to ratchet and torque down to? Sorry, just slightly confused on that.
« Reply #54 on: May 06, 2016, 08:17:10 AM »
I double-nutted the crank studs to turn them in (with a tiny dab of red locktite in the upper case hole) to 8ftlbs.
Easy peasy.
« Last Edit: May 06, 2016, 08:20:03 AM by flybox1 »
Offline SKOL
« Reply #55 on: May 06, 2016, 09:21:44 AM »
Easy peasy.
So when you are looking at the bottom of your engine (upside down), where the bearing studs are, there are no bolt heads? This is confusing the hell out of me.
« Reply #56 on: May 06, 2016, 09:39:53 AM »
Crank bearing studs shown with (ARP thread sealant treated) new nuts.
  • Youngish
« Reply #57 on: May 06, 2016, 09:59:20 AM »
Goes a little fast, but anyway...
Offline SKOL
« Reply #58 on: May 06, 2016, 11:32:02 AM »
huh, so the bearing studs don't thread up from under the bottom case like a bolt would. You thread them down into the lower case half (double nutted to torque to spec), then thread a new nut on at the bottom. I think that's right? haha
« Reply #59 on: May 06, 2016, 11:34:31 AM »
You thread them down into the lower UPPER case half (double nutted to torque to spec), put the two case halves together with an appropriate sealant then thread a new nut on at the bottom. I think that's right? haha
FIFY  ;D
Offline SKOL
« Reply #60 on: May 06, 2016, 11:48:28 AM »
FIFY  ;D
The light has come on.
Offline SKOL
« Reply #61 on: May 19, 2016, 01:56:14 PM »
ARP SS Flange
6x30  x 8
6x40  x 10
6x50  x 4
6x55  x 4
6x80  x 2
6x100 x 7
8x55  x 2
10x80 x 1
Do you know of the thread pitches? Can't find much. Lots of places offer 0.75, 1.0 , 1.25, and even 1.5/1.75/2.0 thread. I was just wondering if you knew before I took a big ol' bag of bolts to the hardware store and checked the thread pitch of every single on of them haha.
  • Youngish
« Reply #62 on: May 19, 2016, 04:00:11 PM »
ARP ones are the correct pitch EXCEPT for the 10mm one, but it does use a corresponding nut on the crankcases so not an issue. The only other odd ball 10mm fine threads are in the lower triple and the brake caliper for (for the 750s, maybe others too). These I just went with chrome plated ones from the same site.
Offline SKOL
« Reply #63 on: May 19, 2016, 05:03:55 PM »
Thanks guys!
Offline AshimotoK0
  • CB400/4, 69 CB750K0, '69 CB250SS, CB350K1 CB500K0
« Reply #64 on: May 21, 2016, 03:16:49 AM »
I use a mix of caustic soda,  EDTA & a dash of  trietholamine (all available on eBay) in a slow cooker at 70 deg C. It's the zinc stripping method that's used in industry. Very gentle on base metal. Here are some parts I had replated after that method of stripping plus bead blast of rusty/corroded parts
This batch (plus a few more parts  not in the photo) cost 50 GBP to have plated in BZP professionally locally in the UK  (some bright passivated, some (eg spoke nipples) gold chromate passivated.
« Last Edit: May 21, 2016, 03:20:03 AM by AshimotoK0 »
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.”
Offline SKOL
« Reply #65 on: May 21, 2016, 07:05:43 AM »
That is a hell of a deal. There aren't Mayne places around me that do zinc plating, lots of Chrome though. Best quote I got from places I would have to ship my bolts to was 120 dollars just for 30 or so bolts. Crazy!
