Author Topic: No power to CB750K6  (Read 1753 times)
Offline Ike
No power to CB750K6
« on: May 04, 2016, 05:58:12 PM »
I was off and on my CB750-K6 all day with no problems. I came home from work and parked it. When I got back on it this evening, no power. The dash lights, horn, starter, etc. would not work. The battery still had a full charge and the 3 fuses on the left side seemed fine. Any suggestions?
Re: No power to CB750K6
« Reply #1 on: May 04, 2016, 07:05:48 PM »
..."fuses seemed fine" is not a proper way to diagnose.
Check them with an ohmmeter.
Offline b52bombardier1
« Reply #2 on: May 04, 2016, 07:07:41 PM »
And I would get the battery "load tested" at an auto parts store - usually a free service.  It is possible that it can't deliver the amps anymore and its worn out.
Rick
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: May 04, 2016, 07:14:05 PM »
+1
CB550 K0
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: May 04, 2016, 07:24:56 PM »
At minimum, pop them out and swap them with some from the spare cache of fuses-that-you-always-carry-with-you-because-it-would-be-dumb-to-be-stranded-by-something-so-small.
Another thing to check would be the key switch.  Check for power on RED, then switch it on and check for power on BLACK.
mystic_1
- John Augustus Shedd
« Reply #5 on: May 04, 2016, 07:28:12 PM »
 Start checking all electrical connections if the fuse checks out and check the old fuse box also . I once was let down for awhile because my ignition switch connector under the gas tank became disconnected mostly because I has the switch located with an aftermarket bracket up by the handlebars. Probably a simple fix when you trace it down.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #6 on: May 05, 2016, 06:03:59 AM »
Be sure to check the earth cable to frame connection as well.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #7 on: May 05, 2016, 07:14:31 AM »
..and the block connectors that can part ways for no reason at all  ::)
Offline Ike
« Reply #8 on: May 06, 2016, 11:11:14 AM »
I got it! It was the 20A fuse. It showed good on the meter but only intermittently. I changed it and all's well. Thanks all.
Ike
« Reply #9 on: May 06, 2016, 02:11:19 PM »
Good!   I'd clean the fuse holder to prevent further issues. Emery cloth works well.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #10 on: May 07, 2016, 07:14:15 AM »
Ike,
Unless you want to keep the K6 absolutely stock, I would suggest you give some thought to the Hondaman Fuse Box.
It is a plug and play replacement of the old style glass fuses with the new blade style fuses.
I can't find the link right now, but I'm sure if you PM Hondaman, he can provide the info you need.
Charlie
Offline zammykoo
    • @Mototam
« Reply #11 on: May 07, 2016, 07:23:05 AM »
Check your grounds, maybe a loose ground connection somewhere near the battery.
Offline Eydugstr
« Reply #12 on: May 07, 2016, 01:16:47 PM »
Ike,
Charlie
+1.  The original fuseholders weren't made to last 40+ years, not too mention it's easier to find the modern blade style fuses.  Here's a link - http://sohc4shop.com/catalog/product_info.php?cPath=23&products_id=48
