Author Topic: 1978 750K ignition wiring issue  (Read 1247 times)
Offline rassmuss
« on: May 05, 2016, 12:58:52 AM »
Hi, new member here .....  I recently acquired a fairly nice 1978 CB750K, however the previous owner lost the ignition key and cut the wiring at the switch in an attempt to hot wire it.  I purchased a new switch and I am a little confused as to which wire goes to each terminal.  There are 5 wires:  1 red, 1 black, 2 brown and one striped brown wire.  I attached pictures to this post and named each terminal, could someone direct me as to which wire goes where?  Thanks!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 1978 750K ignition wiring issue
« Reply #1 on: May 05, 2016, 02:15:08 PM »
I can probably check the connector on a harness here and sort the pinout for you. Might not be tonight though!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline rassmuss
« Reply #2 on: May 05, 2016, 03:20:12 PM »
If you could, that would be a solution to my issue.  Thanks for the reply!
