Author Topic: "78f motor, "74k frame, '76 swing are and rear wheel? cb750.  (Read 623 times)
Offline la ca fe
I am seeing if any of the cb750 gurus here on the forum will know if this set up will work?
1976 cb750k
1975 cb750 f
1977 xs750
1978 xs400
Re: "78f motor, "74k frame, '76 swing are and rear wheel? cb750.
« Reply #1 on: May 08, 2016, 04:40:07 PM »
The 78 engine will require a 10mm offset to everything to the rear using the frame you have.
Offline la ca fe
« Reply #2 on: May 08, 2016, 05:39:52 PM »
I do have a "76f frame as well.
Do you know if the "78f motor's sprocket will align with the rear '76f swing arm and hub?
1976 cb750k
1975 cb750 f
1977 xs750
1978 xs400
« Reply #3 on: May 08, 2016, 08:01:04 PM »
 I know that it will not..
 not sure but offset sprocket on front. might fix it.. or change the sprocket carrier on the wheel , move the shock if you can and prepare to cut or change chainguard..
« Reply #4 on: May 08, 2016, 08:39:01 PM »
 I'm a fan of the 76 frame and swing arm with the rear disc. But that might just be me.
« Reply #5 on: May 09, 2016, 08:23:22 AM »
No, that's what I just did.
Offline riffman12
« Reply #6 on: May 09, 2016, 09:35:17 AM »
76 swingarm and 74 frame will align, the 78 motor will not.
the 77 and newer 750s used a wider chain which required them to push the front sprocket out by 10mm
To make up for this, they had to move the left side of the swingarm out 10mm.
If you really want to make the 78f motor work in the 74 frame, you could buy a 77 or newer swingarm and a wider cush drive for the rear wheel (or a rear wheel from a 77 or newer bike)
There are companies that make offset sprockets and all that, but it's not worth the headache in my opinion.
I tried to make a 77 swingarm work on my 76 750 and it was a giant headache. Ended up just buying a 76 swingarm.
« Reply #7 on: May 09, 2016, 09:46:34 AM »
Yes it will, I have 78SS engine, wheels, swingarm, brakes in K3 frame.  See my signature for the build.
