Author Topic: Show me your steering dampers!  (Read 30319 times)
JWExperience
« Reply #50 on: May 12, 2016, 06:28:59 AM »
I have the same damper as the OP. I put mine on because I got a hairy wobble over bumps at highway speed. Next I'll replace the bushings in my swingarm.
I see that you have different fender. Is it with a bracing as OEM fender?
If not, wobble all over the road.... I got it for many years ago when I used a fiberglass Dunstall fender, no bracing at all, clamped with hose clamps on each lower fork.
+10 on the steering damper kit Wobbly show. I ordered this from Yamiya since my old has started to leak. The rigid frame bracket is vital. I cheaped out back in the days using an exhaust clamp as was common here back then. The damper was not as stiff as it can.
I have a plan to replace the horns with one Stebel kompressor horn (waiting in my garage) and no messy wiring.
Yeah pewe, that is the stock fender, it's just trimmed up some.
I've also read on here that if the rear swingarm bushings are bad then you can get the wobbles.
Prior to my CB, I had a hayabusa. When I rode that on the highway it was rock solid. My CB would be solid until I hit bumps and then the bars would start to shake back and forth, not a tank slapper but didn't provide much confidence. When I was putting my bike together, I didn't notice play in the swingarm but the bronze bushings are easy to install and will be a decent upgrade. Plus they're pretty cheap insurance.
I agree with wobbly, check other areas to fix the problem before covering it with the damper like I may have.
« Last Edit: May 12, 2016, 06:43:06 AM by JWExperience »
Re: Show me your steering dampers!
« Reply #51 on: May 12, 2016, 07:41:29 AM »
Cal, with all respect, there isn't a single market in the world where steering dampers are law. Are they all morons? Many happy openings of boxes.
+10 Practically all unrest at the front is generated in the rear, but try to explain that to people that are addicted to open boxes ('Look what Santa Claus brought me this morning').
« Reply #52 on: May 12, 2016, 10:03:08 AM »
 Hey, not to put a damper on things , but lets see more steering damper pics and less philosophy behind them..
 wish I had a pic of my yet to be installed  Ohlin version..
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #53 on: May 12, 2016, 10:11:58 AM »
better use Money, fix the bike,,, then spend/vaste Money on stering dampers..the damper is medisin...not the cure...
get to the veak point..and fix that.
.go to the root of the problem...instead to fight the symptoms
sohc bikes is relative low power bikes......sport bikes can make use of this
..the only supersport on sohc,, is the marking on the tank..
+1
Speed wobbles and tank slapers are indicative of other issues.
Contributing factors such as inadequate (non-exsisting) suspension dampening, soft spring rates, bearing play, tire wear, and geometry changes/modifications can all lead to stability issues. Start there to resolve your handling issues.
Offline nobody
« Reply #54 on: May 12, 2016, 10:32:02 AM »
Man, that devolved quickly.
I know the lack of a damper isn't the cause of the wobble but it could have prevented a crash. I'm rebuilding everything right now, the bearings, bushings, forks, shocks, refreshing it all because it was all original and worn out. So after all that I probably shouldn't wobble again, but IF I do it would be nice to have a failsafe to help me control said wobble.
74 cb750k
Offline nobody
« Reply #55 on: May 12, 2016, 10:53:13 AM »
I don't understand the aversion to a safety device here, it doesn't negatively affect performance of the bike.
I don't always wear my seatbelt because I don't plan to crash when I drive my car either but when I start tearing around and driving hard you'd better bet I put it on.
74 cb750k
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #56 on: May 12, 2016, 01:36:51 PM »
Hey Matt
Please don't get me wrong. I'm not apposed to your want of a steering dampner it it provides the conference you seek. It's not a cure for other deficiencies though.
« Reply #57 on: May 12, 2016, 01:57:31 PM »
I wouldn't drive my car out of the driveway without my seatbelt on, it doesn't matter how slow or careful you might be driving, you can't account for all the other morons on the road. Belt up and live!
As much as those steering dampers in the pics look cool, I've seen a heap over the years with quite a bit of slack in them before the actual damping starts to work, this was common in the crappy Kawasaki copies that were all over eBay a while ago.
Personally, it'd be of little benefit to have one on a bike, so it'd be a good idea to check your damper regularly for a smooth even damping motion for the full range of movement.
I've got a much better rotary damper on my BMW R1100GS, it Mounts on the top triple so is easily adjusted on the fly, but very expensive compared to the old style dampers in the pics above. Cheers, Terry. ;D
Offline calj737
  • I refuse...
« Reply #58 on: May 12, 2016, 02:31:14 PM »
A damper only increases your handling if adjusted properly, and you should heed FJs counsel. Add it, but always make sure your bike and equipment are in top shape. Ignore the "aversionists" as its your bike and your life.
Offline DaveBarbier
« Reply #59 on: May 12, 2016, 03:27:57 PM »
I added my damper just due to fear. After watching tank slap videos I went right to purchase one. It's relatively easy to install and can dramatically help. As others said, it's not a devise to put a bandaid on your bikes issues, but a nice complimentary add on. But it's not only bike problems that can cause them, road oddities and large bumps can start them too. So even if your bike is rock steady a damper can even further protect you.
We're pretty exposed out there. People, animals, pot holes, sand...they're all trying to kill you. In my eyes, another little helping hand is welcomed with open arms.
« Reply #60 on: May 12, 2016, 04:00:41 PM »
Delta, if you don't know why dampers are used, after being told numerous times already,  its a waste of time explaining it over and over again..
OK, then let me ask this:
Did any of you that experienced wobbles, tank slappers and the like*:
a) Inform Honda that there's something seriously wrong with their product and a steering damper should have been provided?
b) Inform US authorities there's a serious safety issue that needs to be adressed? I'd recommend to report it to the same authorities that did such a wonderful job on warning stickers and mirrors (objects in this mirror...). There can be no doubt they take things very serious indeed.
c) Inform road authorities there's a dangerous situation on road such and such and a warning sign would be the least they could do, responsible as they are for these third world quality roads in the first place?
d) Now we all know how hard it is to pass the US license test. Not only you are supposed to tell your left from your right blinker, you should also know the difference between a green and a red light AND HOW TO ACT and most important of all: the infamous rolling stop at a stopsign that has to be avoided AT ALL TIMES (oh, boy, oh boy, that one tough). Now, are there any of you steering damper users that did take an advanced motorcycle training, like motorcyclecops undergo?
e) Is there an explanation why (overhere) to my memory I've not seen steering dampers on police patrol bikes? And do you think I can sue the unresponsible police trainers that not only showed up on a bike without a damper but also failed to warn us we should start with mounting one?
I apologise in advance for wasting your time.
* Yes, I've often experienced the usual unrest at around 60 km/h. Nothing to worry about as long as both hands rest on the handlebars and yes, I've experienced (only a few) speed weeves at speeds over 160 km/h. Nothing to worry about, just don't sit upright but lower your chest (again) to the tank.
Ok, seams the strawman is alive and well in this post. Lets put a few myths to bed here. The CB750 was designed and built in the late 1960's, the frames virtually remained unchanged for about 10 years, we were no where near the advancements we now take for granted on todays motorcycles, most Japanese bikes of this era were well known for their evil handling traits, these were caused by poor geometry and poor frame design, weak swingarms and poorly damped suspension didn't help either. The early K models were know for their ability to oscillate into a tank slapper due to their relatively small trail numbers, around 3.7 inches, even todays sport bikes with quicker steering 17 inch wheels have trail closer to or just above 4 inches, there's a good reason for this but these bikes still have steering dampers from the factory. Honda went a way to rectifying this in the F models and later K models by reducing trail by 10 mm and adding a little to the rake, both of these changes aided stability, but there's still no problem or reason you shouldn't use a steering damper, its an insurance policy that works and makes riding a motorcycle just a bit safer. It doesn't matter how well you set up a stock motorcycle, there's always the chance you'll get a tank slapper, the causes aren't always a poorly maintained bike, they are caused by resonant frequencies, and it only takes a small bump and the right set of circumstances and it happens, and its scary as hell. I've had 2 tank slappers, one caused by loose steering head bearings on a GT550 Suzuki, I was asked to ride it to see if I could identify why it was wobbling, I ended riding uncontrolled off the side of the road and into a park, that could easily have been worse, the 2nd was on a very well set up 750/4, It had new Koni shocks, tapered steering head bearings good tires and the front end of my mates 750/4 race bike {where i bought my first RC engineering parts}, at that time it was the best handling bike I'd owned and I used to have fun blowing my mates off in the back streets locally, I was riding it quite fast and tipped into a bend in the road, hit a small bump and it went into a violent tank slapper that damaged my steering stop and dented my tank with my thumbs, after that I fitted a damper on that bike, and rode the wheels off it for another couple of years.  If delta is lucky enough to live in a country with perfect flat roads and all motorcycles ever sold to his country were perfect then great, in reality, there are plenty of things that can cause a bike to experience instability, check all the moving parts on your bike, when you are happy its all working as intended, then fit a damper as piece of mind if you want, they DO WORK and are a great little insurance policy...  All modern sport bikes have them stock... ;)
Well, not wanting to argue with the armchair experts here, but Honda actually supplied a (non adjustable) steering damper as an optional item, along with a right hand front brake disc/caliper assembly, an oil cooler, you name it, you could buy it, as an optional extra, they just didn't install them on their bikes in the factory to keep the price down.
I'm not for a moment saying that for everyday use you actually need one, but hell, for 100 bucks they're cheap insurance. Cheers, Terry. ;D
Bingo...!!!
« Reply #61 on: May 13, 2016, 02:53:52 AM »
First: I do not deny that there are certain bikes that under circumstances could benefit from a steering damper but I'm far from recommending them categorally for just any ordinary bike. Then I'd like to dive somewhat deeper in it, so, Terry, if you can give me a partsnumber or anything of the steeringdamper Honda marketed, I'll have a look at it. Having not seen them here I'd like to know whether it is genuine Honda or maybe Honda Australia. This because I know merchandising and where in one market Honda will have mugs with the Honda logo, I wouldn't be surprised that in another local market they do accessories. For example  I've seen VDO oilpressure and -temperature gauges that had the Honda logo. I doubt very much they were Honda btw, the quality was poor (plastic gadgetry) and I've only seen them once.
Now before the usual horror videos dive up with nothing but anecdotal value, I'd recommend to watch this video say from 04:00. Although the sound is a bit poor, the content is very instructive indeed. Most of the bikes shown are of our category and generation. There's some good advice on how to prevent and deal with wobble and weave. Note that in over 13 minutes the word steeringdamper is not used once.
As said before, I experienced some wobbles and at sustained high speeds (>160 km/h) a few weaves but they never made me panick (training?) and the tendecy of the latter was cured by a set of Koni rear shocks. I've put a question on the German site how steeringdampers relate to their annual 'TÜV' test and if they're allowed at all. As soon as I know more, I'll inform you.
« Last Edit: May 13, 2016, 03:41:44 AM by Deltarider »
« Reply #62 on: May 13, 2016, 03:07:19 AM »
The bike will be more unstable with bags and lots of luggage. Not properly tightened front end, swingarm bolt...
..one more thing... the wobble usually start after 160kmh (>100mph).
« Last Edit: May 13, 2016, 03:10:40 AM by PeWe »
« Reply #63 on: May 13, 2016, 03:49:24 AM »
G'Day Mate, No, they weren't an Australia specific part, but I saw them in Honda dealers "back in the day". I've got a genuine period Honda steering damper in a box that a friend in Oregon sent me years ago, so next weekend when I'm back in Melbourne I can take a pic if you like and see if I can find a part number, they were a common damper that Honda supplied for use on a lot of their bikes back in the 60's and early 70's. Cheers, Terry. ;D
« Reply #64 on: May 13, 2016, 04:32:07 AM »
Here's a picture only, I'm not jumping into this.  ;D
Offline brewsky
« Reply #65 on: May 13, 2016, 05:00:34 AM »
Here's mine!! ;)
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
    • http://forums.sohc4.net/index.php?PHPSESSID=3pg1o5mgbjlcuac37rrejtbva2&/topic,60973.0.html
« Reply #66 on: May 13, 2016, 05:54:40 AM »
here is mine on a 69 cb 77... ;D.
.still dont vant one on my cb sohc...uh it not on the Photo...but mostly as the above.
.the handel is just a  bit different .
.it dont aktuly damping..just sqvesse a bit..so it teighten up..not as a hydralik one do..so not aktuly a damper..just teighting the stering
..different animals vith the same name
« Last Edit: May 13, 2016, 06:01:07 AM by strynboen »
« Reply #67 on: May 13, 2016, 06:32:22 AM »
Thanks guys. That looks like an exciting spedometer, Strynboen, must be fun to make them needles go wild.
« Reply #68 on: May 13, 2016, 07:06:24 AM »
Seems the engineers felt the need for some type of dampening on the 60's bikes.
« Reply #69 on: May 13, 2016, 08:30:53 AM »
And neither will I.
1. Never had anything happening in over 100.000 kms on all imaginable kinds of roads in Europe.
2. My dealer back then who owned a CB500 himself (and could easily have sold me one), informed me I didn't need one.
3. I look after my bike. Bushings, tyres, bearings are all in good order. Koni rear shocks cured the exceptional weave I experienced.
4. Never seen one on a CB500P (police)
5. Trainers didn't have one on theirs and neither did they advise us we should have one.
6. I don't like the looks. In fact, I think it looks silly, like some sort of crutch but that's personal.
« Last Edit: May 13, 2016, 08:38:00 AM by Deltarider »
Offline nobody
« Reply #70 on: May 13, 2016, 08:47:31 AM »
To each their own but I wobbled and weaved and crashed on the highway at 80 miles an hour, that #$%* hurt. While I respect that worn out suspension caused the crash, and am currently rebuilding the bike to address such issues, I'm simply not interested in doing that again.
So when you crash a bike at 80 and decide you don't care about adding a damper when all your busted body parts heal up and you get back on your bike again, by all means, that's your choice. But I never came here asking if you thought I needed one, so please stop turning what I intended to be a technical thread about how to mount a damper and what options are available into this ridiculously immature argument over who needs them and who doesn't.
I don't want to wobble to the ground again, I want a damper. Period.
Thank you to those who included valid technical input. It's appreciated.
74 cb750k
Wobbly
« Reply #71 on: May 13, 2016, 09:01:04 AM »
Save your money and get something that is more adequate for you:
Offline DaveBarbier
« Reply #72 on: May 13, 2016, 09:34:30 AM »
Totally! This Matthew guy is a really baby. Only real men don't like safety. I bet you wear a helmet and heed traffic lights too while not drinking alcohol, LOSER!
Wobbly
« Reply #73 on: May 13, 2016, 09:52:15 AM »
« Reply #74 on: May 13, 2016, 10:02:10 AM »
This is a forum.That means more people than just you read the posts. That's the idea of a forum. Sorry, I hurt your feelings although I could do it a bit more: try to buy good well known parts for your bike instead of aftermarket junk the quality of which has been disputed here for years. But then, you never came here asking about that either. Good thing is: you had not just one but two boxes to open, lucky you!
