Author Topic: Having a really bad month  (Read 2332 times)
Offline Mantree
« on: May 13, 2016, 12:52:25 AM »
This month has just been giving me a run for my mony.  A few days back someone tried to make off with my cb750 they didn't make it far before the bike stalled because the regulator rectifier wasn't hooked up, they did however fry the battery and screwed up some wireing.  Then during a inspection of the timing chain on my truck I found that the block had cracked where someone had over torqued one of the bolts on the timing cover so it is being torn down for repairs and a rebuild.  This leaves me with my Yamaha to get to work and back.  Today it was acting kind of funny and then it started to hit a wall about 4.5k so it needs a new fuel filter.  Needing a new filter isn't the biggest problem but with the couple of weeks I have had I am at the end of what I can take without rage quitting
Sent from my ME302KL using Tapatalk
Offline 74cb750
Re: Having a really bad month
« Reply #1 on: May 13, 2016, 01:21:26 AM »
Hang in there....like my wife says,
"it just Might get better, but then again knowiing you"  8)
but seriously, take a deep breath,
and RELAX!
Laugh at least once a day.
Life  $ucks, then you die.
Offline Mantree
« Reply #2 on: May 13, 2016, 02:43:07 AM »
Just realy had to vent a bit.  My father is striping down the engine in my truck and is going to take it to get it welded up.  The first time I rewired my cb750 it took me less than a day to make the loom and wire it all in so it's not a big deal to fix what's wrong and I will be going by the motorcycle shop to grab a new fuel filter and just hope it's not the fuel pump
Sent from my SM-G900V using Tapatalk
scrapvalue
« Reply #3 on: May 13, 2016, 05:28:37 AM »
What ever you do,  Don't make a bad situation worse!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #4 on: May 13, 2016, 05:45:21 AM »
Just remember, somebody else has always got it worse.  :(
Cheer up, I'll be sending you a fork cap soon. The wife says I have to fix the A/C in her car before I do anything else, or find a new place to live!  :o  ;)  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Mantree
« Reply #5 on: May 13, 2016, 06:13:09 AM »
Ya I did that last year for my at the time girlfreind (now wife) she seems to think that colorado summers are to hot, no idea what she means I my truck hasn't had a functional ac since I ran over a tree 2 winters ago (black ice + no abs = 1 uprooted small tree and a busted condenser) but that's why I have 6 windows that open.
« Reply #6 on: May 13, 2016, 06:49:04 AM »
LOL!
Florida summers can be brutal, but I have not had A/C in any of my vehicles either for a very long time. Once I fix hers I might just have to fix mine!  8)
TAMTF...
Wilbur
Projects:
« Reply #7 on: May 13, 2016, 07:49:25 AM »
... I have not had A/C in any of my vehicles either for a very long time.
Dont know how you can tolerate that?!
« Reply #8 on: May 13, 2016, 08:03:00 AM »
You just gotta be tough!  :o  ;D
TAMTF...
Wilbur
Projects:
Offline Mantree
« Reply #9 on: May 13, 2016, 03:42:49 PM »
I just have fans and drive with the windows down 4 in the pasanger compartment 1 in the tailgate and the sunroof
« Reply #10 on: May 13, 2016, 04:07:11 PM »
Your luck is turning around. You don't have a fuel pump. It is all gravity feed.
Offline Mantree
« Reply #11 on: May 13, 2016, 06:49:12 PM »
Not on the yamaha it's tank is under the seat with a lift pump like a goldwing lucky it's a low pressure 12v pump so any electric pump from a carbed engine will work.  Just haze to fit
Offline Mantree
« Reply #12 on: May 14, 2016, 10:49:23 PM »
Well not the fuel filter on the bike
« Reply #13 on: May 15, 2016, 09:50:09 AM »
LOL!
Got some reasonable priced kits over at RockAuto.com.
Offline Mantree
« Reply #14 on: May 15, 2016, 06:52:30 PM »
I have a kit from a car that I was going to install it on before the head gasket blew and we replaced it with the beetle
Offline Mantree
« Reply #15 on: May 20, 2016, 09:05:07 PM »
Well the new 22re is sitting in the garage and should be in by Sunday turns out that my isue with the sidecar rig was that I had bad gas, I drained it all in to a 5 gall jug and had about 1.5 inch of water at the bottom of the can.  Still haven't fixed the 750 as I got married this week and haven't had time but I have some time off next week and finish the wireing on the 450
Offline Mantree
« Reply #16 on: May 23, 2016, 08:16:09 PM »
Ran in to a snafu installing the engine with a bunch of hardware that was to far gone to reuse and some isues with the vacume lines needing replaced.  I will be heading out to my folks place to redo the vacume plumbing and remove the resonator since all it dose is lowers the exhaust tone which I don't care about since I have straight pipes so it kinda sounds like a farm truck.
Offline grcamna2
« Reply #17 on: May 23, 2016, 08:54:50 PM »
Mantree,
You aren't alone w/ this stuff guy  ::). You'll be able to more appreciate the good stuff that's happening in the midst of the 'Murphy's Law' every day junk that never seems to quit.  :D
Offline Mantree
« Reply #18 on: August 03, 2016, 06:12:45 PM »
2 days after getin the truck back together this happened.  After fighting with the insurance I bough this
Smoother ride and way more power than the 4 cylinder 4runner
« Reply #19 on: August 03, 2016, 06:23:19 PM »
When it rains it pours!  :(
Glad you were able to get it replaced.
TAMTF...
Wilbur
Projects:
