Author Topic: 1971 Honda CB500 - Charging Issue (At wits' end)  (Read 14298 times)
Offline Bodi
Re: 1971 Honda CB500 - Charging Issue (At wits' end)
« Reply #75 on: July 15, 2016, 03:04:23 PM »
I can't imagine how the control switches can affect charging. I think you're on the wrong track there.
0.9V drop to the field coil isn't bad, the regulator itself has ~0.5V drop from the switching transistor.
I can't explain why the system would suddenly manage to get up to float voltage.
You've confirmed all grounds are good. What does the field coil ground to? You can attach it to a solid frame ground to be sure it's good.
You can run a jumper directly from battery "+" to the other field coil wire and see what your battery voltage is when running. This puts the alternator at 100% and - if the rectifier, wiring, and stator coil are OK - this can push the voltage over the safe limit for your battery so watch it carefully.
« Reply #76 on: July 15, 2016, 09:52:02 PM »
It is when it's between the battery minus terminal and the ground side of the field coil. ;)
Dave, if the charging problem comes after pressing the starter button, but goes away after turning the key off and back on again, it would appear the problem is related to the M-unit. Did the electric start button ever work properly?
Offline zerodaydave
« Reply #77 on: July 15, 2016, 10:12:02 PM »
Man .. .this thing. It's just so intermittent. Today I got the bike up to 14.64v at 5k rpm. Now it's back to doing the same thing. I have no idea what it is. I've looked at the grounds and they all look good. I even took sandpaper to each one straight to the frame.
The starter button did work for awhile but we have always had issues with it.  And the lights are still flickering at idle and more so when i rev.
Should i be looking between the battery minus terminal and the field coil ground?
« Reply #78 on: July 15, 2016, 10:18:34 PM »
Does the charging system always work if you never use the start button? Are you using stock handlebar switches?
Offline zerodaydave
« Reply #79 on: July 15, 2016, 10:22:04 PM »
Yeah I'm using stock handlebar switches. Both times it did work I ended up kickstarting it and not using the starter switch (which as of today no longer turns the bike on and we're not sure why yet). If you push it now all power to the bike cuts out it just dies.
« Reply #80 on: July 15, 2016, 10:40:13 PM »
If it were a stock wiring system, it would be much easier to trouble shoot than with an M-unit thrown into the mix. If you had a short, with a stock system you would blow a fuse, but the M-unit has built-in breakers that reset. Right now, it sounds like your issue isn't a charging fault, but an excessive load, brought on by pressing the start button. Why the load doesn't go away when the button is released, but does after the key is turned off, is a mystery....
For now, don't even try the starter button at all, and see how the charging system works.
Offline zerodaydave
« Reply #81 on: July 15, 2016, 10:55:04 PM »
Cool I'll give it a try in the morning and post my results. I would love to go outside right now and rev my bike to 5k but I'm sure the neighbors would be pissed!
Offline calj737
  • I refuse...
« Reply #82 on: July 16, 2016, 04:07:14 AM »
Ugh ... So I found it! And I now know what's up. Basically I was doing a compression test for another issue I was having. And when I tried to start the bike for some reason the ignition button wasn't working so I kick started the bike and drove it around the neighborhood. Came back and tested it again and this time 14.64v at 5k rpm! Turned off the bike and was super stoked! Obviously I didn't believe it so I tried to start the bike again with the starter button and it didn't work. Kick started it and only 13.50v at 5krpm what gives? Hit the ignition button again and the bike just cuts out. Turned the key off and kick started it and again 14.64v at 5k rpm. So it's something with the right hand controls! Specifically the ignition starter button. Grrr ....
Hey Dave - Can you provide some greater clarity here? You are saying you push the electric START button on your stock handlebar switch? I ask, because you keep referencing ignition button and want to make sure you're not talking about a car type key switch. Also, you kick started the bike, but then hit the "ignition button" (you mean START, right?) and the bike died? If so, that is normal-ish. The m-unit uses a single press to start the bike, but a double press of that button will kill the motor. It sounds as though the start button is faulty and is not releasing from the bars, essentially grounding out. This would explain Scottly's thinking about an undue load being seen by the m-unit because it (the m-unit) would be attempting to transfer power to the solenoid constantly while the start button were stuck.
Pop your seat off (or wherever you mounted the m-unit) and shoot some video. Key off to begin with, then hit the START button. Measure the voltage on AUX (try to keep it in the video frame) before, during and after you start the motor.
Plot twist discovered this this morning. See attached. The bike was still running because we were apparently bypassing the fuse wired directly to the battery. We removed that wire and we are now going through the fuse.
I don't know which fuse this is? Is it the fuse between the battery POS and the m-unit? Are you saying that by wiring the m-unit through that fuse, when electric start is used, it blows that fuse?
It would be helpful to see the m-unit, how its wired, and the solenoid/battery and their grounds. I seem to recall you had a buddy help you wire this up. Is he around to help troubleshoot?
Offline zerodaydave
« Reply #83 on: July 16, 2016, 02:35:22 PM »
Hey Cal!
Honestly we are just super frustrated right now. And yes I've talked about pushing the bike off a cliff or stuffing a rag in it and lighting it on fire lol!
My buddy has been troubleshooting it with me the entire time and I have been showing him all of the posts. I was talking about the start button. Thanks for clarification on pushing it twice to kill the engine. That's awesome and we both didn't know that. We completely bypassed the start button today by removing all the wiring from the m-unit. Still not working. We're both unclear on how to test the AUX port. Is it neutral or positive on the battery to test?  Also he said he wired the start button to start on the munit not aux.
It's also difficult getting a good reading when the multimeter leads are connected to the +, - terminals because it just jumps around so much. We've tried new batteries it just does the same thing. Not when the bike is not running. Especially when we rev the engine.
Also the solenoid is bad and I bought a new one eBay. No click when you push the start button. Tested with a screwdriver and it arched but didn't activate. So we bypassed that to see if that was it and it's still the same thing.
Thank you everyone for the time and responses. I am totally new at this but I am learning a ton. I never thought I would be tearing my bike apart on the side of the road with the ability to put it back together and be on my way which I did today!
« Last Edit: July 16, 2016, 03:52:51 PM by zerodaydave »
Offline calj737
  • I refuse...
« Reply #84 on: July 16, 2016, 05:35:05 PM »
We're both unclear on how to test the AUX port. The AUX port will provide 12v switched power out. RED probe from meter on AUX, BLACK probe on battery -.
Also he said he wired the start button to start on the munit not aux. Thats correct. Handlebar start button Yellow/Red wire to left side START, START output from right side to solenoid as power!. You need a ground at the solenoid this way.
It's also difficult getting a good reading when the multimeter leads are connected to the +, - terminals because it just jumps around so much. Are you saying you get a non-steady voltage reading? Thats usually a sign the contact of the meter probes is not good, or the battery NEG is grounded well. Check the terminal connections, and really check the ground connection to the motor/frame.
Also the solenoid is bad and I bought a new one eBay. No click when you push the start button. Tested with a screwdriver and it arched but didn't activate. So we bypassed that to see if that was it and it's still the same thing. Probably this has more to do with the way the m-unit is wired to it versus stock. Can you post a really clear picture of the wires on top of your solenoid please?
Offline zerodaydave
« Reply #85 on: July 16, 2016, 06:41:45 PM »
Here you go. There is a wire running from Start right to solenoid.
Aux is 12.90 on key on and 12.80 running at idle.
I found this too. I want to say that's the issue but this bike is annoying as all hell and most likely it's not. That yellow wire was from the back of the stator connection. I believe it's a stator wire. It was hanging on by a strand and I easily plucked it off with my finger. The red wire in the pic goes to the top of the solenoid.
« Last Edit: July 16, 2016, 06:43:43 PM by zerodaydave »
« Reply #86 on: July 16, 2016, 07:07:11 PM »
The loose yellow wire would explain the on/off charging issue!!! Those are REALLY #$%*ty crimps!!!!
Offline zerodaydave
« Reply #87 on: July 16, 2016, 07:30:42 PM »
My fingers are crossed but my bike hates me. Those are some pretty #$%*ty crimps. I will let my buddy know and post an update.
Aux reading look good?
« Reply #88 on: July 16, 2016, 07:38:45 PM »
Solder those connections, and any others done the same way. You will have to remove the lugs from the plug housing first, and you should re-form the crimps with pliers into a more cylindrical shape. As far as any M-unit readings: :-X
Offline calj737
  • I refuse...
« Reply #89 on: July 17, 2016, 04:03:05 AM »
AUX at 12.90/12.80 is the same as the stock BLACK keyed wire. I wanted to know if it was seeing too high a voltage (its not) that might be causing an overload.
For Scottly's benefit:
The bottom left port of the m-unit is LOCK. This is the "trigger" port to excite the m-unit from a switched 12v source (think key BLACK on our CBs). That single port allows the m-unit to transfer power from the left side to the right side to any component wired to the unit. The AUX port is a utility port. The ignition/coils are wired to it, usually cluster backlights, and the tail light often (some people use a single wire scheme from the BRAKE port to power their tail/brake functions though).
The voltage on LOCK and AUX should always be exactly the same, and should be within 0.1v of the battery unless someone has done a wonky job wiring. Any time you trigger the m-unit to power a function, a light on the left illuminates to indicate that circuit is active, and the corresponding right side port will light up as power is transferred. You can while the right side is illuminated, touch the clamping screw and read the voltage or amperage being drawn.
In Dave's case, I would love for him to have a view of the m-unit, bike ON, and hit the electric start button and observe whether the right side light comes on, stays on, or flashes. That would indicate a fault. But first, fix the stator wiring!!!!
Offline calj737
  • I refuse...
« Reply #90 on: July 17, 2016, 04:05:07 AM »
The thin solid BLACK wire on top of the solenoid, where does it go with how you are wired? Stock, it should wire to power. With the m-unit wired as you have it, the BLACK now becomes a GROUND as the YELLOW/RED are no power.
Offline zerodaydave
« Reply #91 on: July 17, 2016, 10:17:06 AM »
Black is ground. And the red yellow wire is connected to a blue wire which goes to START out.
and the video is attached of the munit while bike is starting.
« Last Edit: July 17, 2016, 10:23:27 AM by zerodaydave »
Offline calj737
  • I refuse...
« Reply #92 on: July 18, 2016, 05:20:20 AM »
So that all looks normal. Remind me, you are running the TAIL light thru BRAKE as a single wire? That would explain why BRAKE is solid. And it sure started up immediately. Why do you think you have a solenoid issue? Or is that the replacement solenoid installed?
Offline zerodaydave
« Reply #93 on: July 18, 2016, 07:47:12 AM »
Because sometimes the starter button doesn't activate the solenoid at all when you push it. You hear no click. It doesnt do anything. It was only $9 on ebay so I just grabbed a new one.
Yeah the brake is always on.
I'm going to fix the connector today and I will report back the results.
Update: fixed the connector and cleaned up the m-unit area. Pictures attached. It's still not working. Now it's not passing any voltage.
Any ideas? Beyond frustrating.
« Last Edit: July 19, 2016, 03:17:15 PM by zerodaydave »
Offline zerodaydave
« Reply #94 on: August 17, 2016, 11:59:08 AM »
So I actually put a jumper cable on the + terminal and connected to the white field coil wire and the bike is charging. Not at 14.5 but 13.65. Without the jumper cable it doesn't charge at all.
What's weird is with the bike running I tested the voltage all the way from the + terminal to the white field coil wire connector where it exits the stator case and there is no loss in voltage. It's the same as the battery. How weird is that.
It doesn't charge without the jumper cable.
I took a break from the bike for awhile because it was so frustrating but I'm back at it.
