Author Topic: High Horse Chopper at the Strip  (Read 974 times)
Offline stikman
  • Bit of an
« on: May 18, 2016, 02:55:30 AM »
I rode my CB750A out to the track this past Sunday since I was racing our drag car.  I haven't run the bike at the track since last year, before I swapped out the 5.25/5.50-17 vintage Firestone car tire setup for an MT90-16, and I've been wanting to see the difference in the numbers.  I only got a couple runs on the bike, but my best was 14.81 @ 93.67 mph with a 2.522 60ft (track is at 2267' elevation).  Super boggy off the line because I'm not at all used to the slow roll onto the throttle at launch (in the race car it's throttle to the floor up on the rev limiter and just lift off the brake to launch).  Last year I ran a 15.38 @ 90.47 mph with a 2.381 60ft.
Of course, I didn't build it to race but it's still interesting to get some numbers anyhow.  Just thought I'd share it with you fellahs.  Here's a vid:
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline Bill/BentON Racing
    • BentON Racing
Re: High Horse Chopper at the Strip
« Reply #1 on: May 18, 2016, 04:38:45 AM »
Thanks,  c'mon to a Man Cup event! What was your launch rpm/ procedure? G'luck,  Bill
BentON Racing Website
BentON Racing Facebook
Offline gschuld
« Reply #2 on: May 18, 2016, 07:09:33 AM »
I like your style.  Obviously it's not the most ideal setup for drag strip use, but I'm sure you knew that :)
Looks like a hoot to ride though...
George
Offline stikman
  • Bit of an
« Reply #3 on: May 18, 2016, 11:13:00 AM »
Cheers, George.
Bill, I never checked my tach while stalling it up (would need more seat time to be able to add that to the focus).  I basically held the brakes (eventually tried rear only, as the front drum is pretty weak anyhow and that freed up my throttle hand), brought the rpms up, and lifted off the rear brake to launch while trying to roll the trottle on slow enough to not stall it.  Seems like maybe I should not even twist the throttle on launch until the bike gets a little momentum, so as not to bog...?  They ran the bikes on a pro tree to even things out I guess, because there were only about 5 bikes and a sled so they ran us all in the same class.  The pro tree was brutal, so I tried a deep stage in that run in the video.  I might try a Friday night with it again when it's just time trials.
Offline stikman
  • Bit of an
« Reply #4 on: May 18, 2016, 11:17:22 AM »
Also, when I staged on round one in that vid I hadn't noticed they misread my 14.80 dial in as 14.20, so I had no chance in that race anyhow.
Offline Big Jay
    • CBRzone
« Reply #5 on: May 18, 2016, 11:43:54 AM »
I think the sled had APE parts in it.
Offline Jim F
  • go baby go
« Reply #6 on: May 18, 2016, 01:46:56 PM »
very cool looking too
J
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
    • BentON Racing
« Reply #7 on: May 18, 2016, 03:42:09 PM »
Cool, we still learn every time, thanks,  Bill
