Author Topic: CB750 K4 chain length -smaller front sprocket  (Read 1232 times)
Offline BobR
« on: April 14, 2018, 12:11:33 PM »
  Ok been a while since I posted. Bike has been on hold. Getting ready to buy a few things to finish up -one is a front sprocket. Been thinking of going down a tooth to a 17.  Question- using stock size 48 rear with the 17 front will I need a shorter chain? TIA Bob
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
Offline Bankerdanny
  • Endeavor to persevere
Re: CB750 K4 chain length -smaller front sprocket
« Reply #1 on: April 14, 2018, 12:15:50 PM »
1 tooth shouldn't require a shorter chain, but it depends how stretched your current chain is.
Offline BobR
« Reply #2 on: April 14, 2018, 12:20:34 PM »
  Thanks! New rear sprocket and chain. I'll order a 17 tooth and 100 link chain then. Bob
 CB750K4(F2 engine)
« Reply #3 on: April 14, 2018, 01:04:28 PM »
100 links chain is perfect for your bike. 17 or 18, 48 rear.
The modern o/x-ring chains do not stretch as the old weak chains.
Offline BobR
« Reply #4 on: April 14, 2018, 01:56:51 PM »
  Thanks! The weathers starting to break around here - parts are ordered! :) Bob
 CB750K4(F2 engine)
