Author Topic: 16 vs 18 inch rear wheel  (Read 4468 times)
Offline 88blkiroc
« on: May 14, 2016, 07:53:24 PM »
So I just picked up another 74 CB750 today as a parts bike for a sweet deal. Even came with a spare engine so I'm pretty happy with the deal. The main reason I picked it up is the rear wheel on my bike is bent (possibly the front too) so for the price everyone wanted for two wheels I got almost two bikes worth of parts. I looked the rims over before I bought it and they look good. Then I get it home and on a closer look the rear wheel is a 16 inch instead of 18. Its a old 5.1x16 tire on it. So the question is what to do now. Go with this 16 or try to find an 18? I wouldn't mind running a 130 rear tire so that seems like a plus but what are the downsides of the 16 if any? Tomorrow I get to dig through all the boxes and see what all I got with the bike :) if anyone needs parts near Chicago let me if you need anything, the tank and rims are staying but I'll probably sell everything else off.
« Last Edit: May 14, 2016, 08:02:33 PM by 88blkiroc »
74 CB750K slowly turning cafeish
74 CB750K parts bike
70 CT70 Trail 70
07 Yamaha PW50 (kids 1st bike)
Former:
01 Shadow Spirit 1100
88 NX125
68 S90 Dream
Re: 16 vs 18 inch rear wheel
« Reply #1 on: May 14, 2016, 09:55:57 PM »
The 16" is good for a chopper/cruiser stance and handling.  I'd ditch it for an 18".
Offline dhall57
« Reply #2 on: May 15, 2016, 04:22:33 AM »
The PO of both my KO and K6 put a 16"(Harley) wheel on them. Popular thing to do back in the day, just like removing the factory exhaust I guest. I like the beefier look from the rear but don't like the side view. Just to much space between wheel and fender,
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline 88blkiroc
« Reply #3 on: May 15, 2016, 05:47:56 AM »
Got any pics of the 16's on your bikes?
70 CT70 Trail 70
Former:
88 NX125
68 S90 Dream
Offline dhall57
« Reply #4 on: May 15, 2016, 07:38:36 AM »
Old pics but they show the 16" wheels. When I need new tires more than likely I'll get 18" rims and tires to put back on. Im a stocker kind of guy ;) From the first 2 pics you can see the distance between the tire and fender that I don't like.
« Last Edit: May 15, 2016, 07:46:26 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
« Reply #5 on: May 15, 2016, 08:26:36 AM »
 We used to run them for longer tire life and other reasons.  One buddy ran a 16, morris wheels front ant rear , S&W shocks... most could never catch him whether you had a 16 or 18 inch rear...
Offline 88blkiroc
« Reply #6 on: May 16, 2016, 03:55:04 AM »
What are the other reasons 754?
Dhall thanks for the pics. Excellent looking machines you have there. I don't mind the gap so much but I like the look of the wider tire.
70 CT70 Trail 70
Former:
88 NX125
68 S90 Dream
Offline Swoop
« Reply #7 on: May 16, 2016, 04:37:18 AM »
Funny, I would have thought the tire would wear faster due to the additional number of rotations to go the same distance.
« Reply #8 on: May 16, 2016, 06:05:16 AM »
I went from 16 to 18 on Dorothy, prefer taller bike too.
« Reply #9 on: May 16, 2016, 06:10:35 AM »
The sidewall on the 16 is usually taller than on the 18. So the overall height, circumference, etc is not much different. The carcass of the 16 is bulkier, and since it has more mass to distribute heat, it runs cooler and lasts longer. I think.
Offline Swoop
« Reply #10 on: May 16, 2016, 06:38:15 AM »
Makes sense.
« Reply #11 on: May 16, 2016, 09:03:55 AM »
For looks and for traction, there was a time a 4.25 x 18 was the widest 18 available.
Also, if runnng struts or rigid, a 16 with say 18-20 lbs of air had more cushion and comfort.
 Of coursevall this flys in the face of the Church of Maximum Handling crowd.... But hey thousands of riders did it..
 With lowering blocks, the gap disappeared.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #12 on: May 16, 2016, 09:14:54 AM »
I looked at a 550 yesterday with a 16" rear wheel and lowering brackets. A sweet chopper seat too.
Offline Tews19
  • I am no
« Reply #13 on: May 16, 2016, 09:24:24 AM »
Danny, I tried to get that!
1970 Honda CB750 survivor.
« Reply #14 on: May 16, 2016, 10:25:34 AM »
 Back in the day, lowering blocks were standard equipment with a 16 rim. Pullback handlebars, backrest, windjammer, highway bars, bell bottom pants, oops I got carried away. The other parts are easy to remove, the 16" rim not so easy.
  My sandcast had a 16" but the rolled 18"  rim was on the PO's mechanic's drag bike. I had to buy it to get the rim. lol.
Offline Bankerdanny
« Reply #15 on: May 16, 2016, 11:35:31 AM »
That particular bike? He still has it. I told him I thought $400-$450 was about right and he countered with $500.
Offline 88blkiroc
« Reply #16 on: May 18, 2016, 08:44:33 PM »
Any rubbing issues with 130/90 tires? Is that about as wide as I can go?
70 CT70 Trail 70
Former:
88 NX125
68 S90 Dream
« Reply #17 on: May 18, 2016, 09:09:47 PM »
130 is fine.. 140 will probably clear..
« Reply #18 on: May 19, 2016, 07:27:07 AM »
The first place it hits is the brake stay bar. You can swing it to the outside of the bracket and a 140 should clear. Next foul is the chain, not much you can do about that.
« Reply #19 on: May 19, 2016, 09:16:27 AM »
 When it hits the tire, break out the disc grinder and take an 1/8 off the tire.. but a 130 will be fine..
