SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Chain/sprocket setup
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Chain/sprocket setup (Read 1697 times)
theslayedsaint
Hot Shot
on:
May 17, 2016, 10:23:53 AM »
Ok. had one more thought on this mesh up of a bike ive got going. i'm replacing the sprockets and chain and was thinking of just using the stock 71-76 k setup from 4into1
http://4into1.com/parts-unlimited-chain-and-sprocket-kit-honda-cb750k-1971-1976/
but with the frame being a 78 F should i be using the F stock setup? my thought is it shouldn't matter but maybe i'm wrong and the chain length is way different.
Logged
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
754
Really Old Timer ...
Re: Chain/sprocket setup
Reply #1 on:
May 17, 2016, 10:30:33 AM »
Probably requires a slightly longer chain, as swingarm is a few links longer.
Tooth count would be vastly different as the 530 links are 5/8 between pin centers and 630 is 3/4.
Logged
Kelowna B.C. Canada
theslayedsaint
Hot Shot
Reply #2 on:
May 17, 2016, 10:41:25 AM »
so going with a 630 chain would be better for this setup? looking for the cheaper option on this one.
Logged
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
754
Reply #3 on:
May 17, 2016, 12:25:42 PM »
i wouldnt run a power sucking 630.. unless your chain maintanence is nill.. then it may get slightly longer life.
Logged
Kelowna B.C. Canada
seanbarney41
not really that much younger than an
Reply #4 on:
May 17, 2016, 01:21:51 PM »
what have you got? what year motor, frame, swingarm, sprocket carrier?
Logged
theslayedsaint
Hot Shot
Reply #5 on:
May 17, 2016, 01:55:20 PM »
Ok what I think I have
78 F frame
75 K engine
The wheel and swing arm look different then my k4 so I'm guessing it's the 78f
What do you mean by sprocket carrier?
Logged
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
JWExperience
Guest
Reply #6 on:
May 17, 2016, 02:38:54 PM »
It is the part that the sprocket is bolted to and inserts into the hub of the rear wheel.
Maybe pics of what you have would help? Do you have comstars? Or spokes?
You may need to swap sprocket carriers or get an offset front sprocket.
There are threads in here that discuss the lengths and widths of f and k swingers so with a little research you should be able to find a lot of this info quickly.
Logged
seanbarney41
Reply #7 on:
May 17, 2016, 02:45:35 PM »
If you have 75k engine and 78f or k sprocket carrier your front and rear sprockets are out of alignment by 10mm...probably why your chain and sprockets are currently needing replacement if you or previous owners have been running the bike like that for very long
Logged
theslayedsaint
Hot Shot
Reply #8 on:
May 17, 2016, 08:24:40 PM »
Ok here's some photos I'm pretty sure it's a f bike with just a k engine. I just bought this bike as a barn find and it was sold as a super sport, because I didn't know much about the SOCH super sport I didn't think that the engine was a k at the time.
Logged
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
754
Reply #9 on:
May 17, 2016, 11:20:04 PM »
Ok so here is the deal.. want to run wide rubber .. stick with the offset.
Want to run smaller normal tire, go to pre 77 spacing..
Logged
Kelowna B.C. Canada
theslayedsaint
Hot Shot
Reply #10 on:
May 18, 2016, 04:09:52 AM »
Perfect I've got a pre 77 catch around here some where I'll switch it out. What about the chain... 530 or 630?
Logged
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Don R
My Sandcast is a
Saver of unloved motorcycles.
Reply #11 on:
May 18, 2016, 09:31:49 PM »
530
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
