Author Topic: CB400 Four, version 9.0 for ME I flip for 400 fours  (Read 31450 times)
Re: CB400 Four, version 9.0 for ???
« Reply #25 on: May 19, 2016, 10:49:28 PM »
You're on a mission . . .
Offline MoMo
  • Ride like you're invisible
« Reply #26 on: May 20, 2016, 02:07:50 AM »
Momo,
You can't standby and let one of these bikes be crushed, you must like raising the dead...
Is that a sulfur yellow?
You have something to keep your hands busy with now.
It might keep you out of trouble. ;D
Watching this one develop...
David
It is a rattle can job not parakeet yellow, so I don''t know what it is but I do have a fondness for yellow 400 fours
one of my favorites
Hope all is well at your end David...Larry
Offline MoMo
« Reply #27 on: May 20, 2016, 02:16:07 AM »
Along with most any Mel Brooks movie and Airplane the Blues Brothers are my top of the line movies.
  It's a hundred and six miles to Philly,  I've got a full tank of gas, half a bucket of brains, it's dark, and I'm wearing sunglasses.
Welcome all.  I hope to do this old, neglected 400 justice...Larry
Offline MoMo
« Reply #28 on: May 20, 2016, 02:20:54 AM »
nice that the piston vas stuck in upper posision..so most of the bore is.. prob.. not rusted..a sqvz of aft and diesel and some heat..and it vill boil.. and free it up...dont use asetone and fire at same time ::)
I've seen videos where people actually light whatever solution on fire in an attempt to free the seized piston.  I have a spare cylinder but I removed the liners and sold them to a forum member.   Also, I have two sets of pistons stashed somewhere
Offline MoMo
« Reply #29 on: May 20, 2016, 04:47:04 AM »
Kerosene or SeaFoam. Kerosene is far cheaper if you can source it locally.
I've used Seafoam to unseize.  The seller of the bike gave me Kroil, which is presently in the cylinder.   Are recommending putting kero in the cylinder and lighting it up???  thanks for your input....Larry
Offline b52bombardier1
« Reply #30 on: May 20, 2016, 04:55:02 AM »
Some high wattage heat gun heat around the cylinder can also work. Takes longer but less chance of catching something on fire.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1972 Candy Yellow CL100 K2
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
Offline MoMo
« Reply #31 on: May 20, 2016, 05:16:35 AM »
Rick
I have a high wattage heat gun as well as a propane torch. thanks for posting...Larry
« Reply #32 on: May 20, 2016, 08:55:28 AM »
Rick
If the motor is out, who cares? Have you seen Cal's engine unseize cocktail??
Offline MoMo
« Reply #33 on: May 20, 2016, 03:44:34 PM »
Rick
motor still in frame with head off.  Haven't seen the cocktail
« Reply #34 on: May 20, 2016, 05:19:13 PM »
His cocktail can't beat my blend of diesel fuel, kerosene and alligator blood. This is Louisiana, after all.
Rick
Offline MoMo
« Reply #35 on: May 20, 2016, 09:13:47 PM »
Only #4 is seized, it has been soaking in a mix of Kroil and Seafoam only a day-didn't budge one bit tonight.  I lit it up but not for long, when i get a chance I'll burn it for a couple hours.
Offline MoMo
« Reply #36 on: May 20, 2016, 09:47:07 PM »
Removed more parts after I got home from work.
notice the beautiful S-curve design of the overgrown brake line :P
Offline MoMo
« Reply #37 on: May 20, 2016, 09:51:28 PM »
 the standard headlight chip from not putting the lip on the rim under the shell.  Most every 400 I ever had had this piece broken off :(
Also the shell is damaged worse than I thought
Have a spare shell but it also has the standard missing piece
Offline MoMo
« Reply #38 on: May 20, 2016, 09:55:23 PM »
Tried firing up the stuck piston but did not realize I needed to torch it for several hours,
that is burning Kroil BTW...Larry
Offline MoMo
« Reply #39 on: May 20, 2016, 10:05:01 PM »
Notice the special custom made rear turn signal cushions, I think the PO should patent that design and market as I've never seen a finer product
« Reply #40 on: May 20, 2016, 10:43:50 PM »
Momo,
David
Yeah buddy,you give this old girl that special touch Larry  ;) a 1977 model/yr. ?
« Last Edit: May 20, 2016, 10:50:49 PM by grcamna2 »
Offline zammykoo
    • @Mototam
« Reply #41 on: May 21, 2016, 08:08:10 AM »
Looking forward to see if the burning kroil works out for you. I released my stuck piston by tapping the jugs with a piece of wood and mallet, on where I felt were the beefiest/strongest parts of the aluminum. Took several times going back and fourth between the left and right sides to raise it evenly. This was after trying to torch the piston with map gas and soaking in marvel mystery for several months.
Offline MoMo
« Reply #42 on: May 21, 2016, 08:52:44 AM »
[/quote]
early production run 1001342.  If it were a 77 I doubt I would have been tempted to buy it
Offline MoMo
« Reply #43 on: May 21, 2016, 08:54:43 AM »
I've been smashing with a fairly large dead blow. 3 pistons free, only #4 stuck(and it is STUCK >:( >:()
Offline zammykoo
    • @Mototam
« Reply #44 on: May 21, 2016, 10:26:11 AM »
I feel your pain! My #3 piston was the last one to get unstuck. My method was to try and utilize the crankcase' weight as leverage by strapping the jugs to my makeshift mini gantry. I actually had 3 straps (2 not pictured for some reason) left, center, & right sides. I believe this really helped me get it off. Once strapped evenly distributing the weight, I hit the jugs upward with the wood/mallet. The engine is fully suspended an inch lifted off the cart at this point. I didn't have to smash that hard because with each hit, the engine weight helped sag it out slowly.
Offline MoMo
« Reply #45 on: May 23, 2016, 06:07:40 PM »
Is it soup yet?
Tried the other day but not had much luck.   The Kroil/Seafoam  is still in the cylinder. Burn Kroil for a couple hours, fire out and add acetone rather carefully, relight with Seafoam??? Does that seem like a plan???? I am off tomorrow so I'll have most of the day,  unless I go out to buy a Kawasaki Concours that is...Larry
« Reply #46 on: May 23, 2016, 06:53:11 PM »
That "recycled taco meat" on the piston almost made me wanna puke!
Subscribed but plz dont show that again!
Offline MoMo
« Reply #47 on: May 23, 2016, 08:23:57 PM »
You mean this, right?
« Reply #48 on: May 23, 2016, 08:34:56 PM »
ARGHHHH!!!!!!!!
« Reply #49 on: May 23, 2016, 11:47:18 PM »
Piston Diarrhea
