Author Topic: vance and hines pro pipe for cb750  (Read 1619 times)
Offline Hockers Choppers
  • go away winter!!!
« on: November 17, 2006, 05:57:11 AM »
Does anyone know if the Vance & hines headers for 79 and up 750s will fit the 78 and down 750's? I've seen a guy with the pro pipe on his 78 cb750f but it hangs low on the right side. Looks like you could use it as a kickstand! Plus it has no baffle!! The other pipes v&h make tuck under the frame more but I don't know if they will fit. Anyone tried these?
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: vance and hines pro pipe for cb750
« Reply #1 on: November 17, 2006, 07:51:58 AM »
Every "Pro Pipe" I have ever seen hangs low like a sewer pipe, as it is intended for drag racing, and not carving corners..
