Author Topic: How to lift 550 for maintenance  (Read 2398 times)
Offline b1jackson
« on: May 19, 2016, 04:42:43 PM »
I bought a hydraulic lift to raise the bike but the 4 into 1 header hangs below the frame and I don't see a spot where the jack pads will sit flush on the frame.
Has any modified these jacks or is there a better way to raise the bike?
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Offline Farley121
  • 78 CB550K
Re: How to lift 550 for maintenance
« Reply #1 on: May 19, 2016, 05:42:51 PM »
Im in the same position, would love to see what others are doing.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 19, 2016, 06:05:58 PM »
If you want to use a standard bike jack you'll either have to remove the exhaust or modify the jack to accommodate the exhaust.  I've never done it, so I can't offer any help in that area, but I can say that in all the rebuilds I've done I've never needed a bike lift.  I use the center stand and a floor jack to get both wheels off the ground.  Others have successfully used straps to hang the front of the bike from a rafter.
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« Reply #4 on: May 19, 2016, 07:08:21 PM »
I use the standard/cheap foot peddle motorcycle lift on my CB550F.  I just position 2X4's under the frame which allows me to have the lift arms lower than the pipes.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #5 on: May 19, 2016, 10:45:01 PM »
Yup, additional lift blocks may be the best way to jack up your bike.
Unless you trade the hydraulic lift in for a set of track stands!
Offline b1jackson
« Reply #6 on: May 20, 2016, 01:23:52 AM »
Thanks for the ideas.  I'll see what I can come up with.  I should add my center stand is removed and gone but perhaps the mounts where it was can be used for something as a lift point.
Offline Gene
  • Chat enuf you too can be a
« Reply #7 on: May 20, 2016, 12:44:42 PM »
You can buy a center stand and use it for maintenance, you don't have to reinstall it altogether, just when you need it.
http://www.ebay.com/itm/1978-Honda-CB550-CB-550K-550-centerstand-center-stand-prop-spring-/321765801962
*1973 CB750K3 (Bow)
Offline DaveBarbier
« Reply #8 on: May 20, 2016, 12:58:10 PM »
That's exactly how I store my bike. Just don't use the spring.
    • http://forums.sohc4.net/index.php?PHPSESSID=vtbhca9t7iqfapbfe0hseb91o3&/topic,60973.0.html
« Reply #9 on: May 20, 2016, 01:06:20 PM »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #11 on: May 20, 2016, 04:45:56 PM »
I built one of these
Works great with 4-4s
How it's made, use 2 sizes of hole saw to create the cradle for the plumbing bits
« Last Edit: May 20, 2016, 04:53:38 PM by OldSchool_IsCool »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #12 on: May 21, 2016, 11:03:41 AM »
That's so wonderful you could sell it.  Just add some adjustability to final spacing between the u-shaped frame grabbers and it could be used for any dual tube cradle frame bike (HD honda teinlh borton whatever!
JWExperience
« Reply #13 on: May 21, 2016, 03:11:11 PM »
That is a great idea, well done!
I picked up some viper paddock stands on eBay and spools for the rear. Going to get a front headlift attachment for my front stand so I can take the wheel off. They seem very solid.
On a side note, I have a cb750 center stand im not using if anyone is interested.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #14 on: May 21, 2016, 03:53:30 PM »
Fantastic job. Very creative.
« Reply #15 on: May 21, 2016, 07:36:01 PM »
I use a 4" ratchet strap attached to the joists in my garage.
Allows a lot of room when working under the bike
