Greetings, everyone! New member here from the wonderful state of Michigan (amount of sarcasm is up to you).
I've been riding for about 6-7 years, and am no stranger to vintage motorcycles. My first bike was a 1980 XS1100, which I no longer have, but I followed it up with a 1984 GL1200 Standard (last model of the naked Goldwing), a 1977 GL1000 that turned into a 1976 GL1000, a 1980 KZ1300 (with lots of '79 parts), and a (I think) 1968 CT90.
However, I just recently acquired my first CB750- a 1972 K2 model, as I recently found out. I"ll get some photos up after I hit the right post count, but I got it in pretty rough shape. It had been sitting in a shed for about 30 years, 20 of which the shed didn't have a roof.
The Good-Most everything is stock, and still there. The airbox is missing, the carbs on it are wrong for the year (they put on the early K0 carbs), and the grab bar was replaced by a sissy bar, but apart from that everything appears to be intact.
-The motor is free, and (far as I can tell) all 4 cylinders have compression. Not sure if it's good compression, but they have it. There's even a bit of oil left in the side tank.
-All things considered, parts are in pretty decent shape. Not exactly clean, but mostly intact.
The Bad- It HAS set outside for 20 years. Tank is nearly a write-off. The top paint is trashed, the interior is solid rust, and I'm not ruling out pinholes.
- Most of the electrical components (switches, etc.) will have to be replaced. I've just started chasing sparks and I've already found the ignition switch to be faulty. I'm guessing the handlebar switches are next, but we'll see.
- There's moss on the crankcase.
So yeah. I've got a long road ahead of me, and I'm not ruling out cutting my losses and parting the bike out, but for now I'd like to stick it out. I've got a manual coming the mail, but I'll still probably be asking plenty of questions (and possible donations...). The goal is to get the bike running and roadworthy, not necissarily pretty. I may clean it up later, but first priority is to get it running.
Here's to hoping I can do it with a minimum of tears and bloodshed....
![Tongue :P](http://forums.sohc4.net/Smileys/default/tongue.gif)
