Author Topic: Round tube swingarms that fit the CB750K  (Read 3662 times)
Offline Mr Freeze
« on: May 24, 2016, 07:17:47 PM »
Hey everyone. Looking for an answer about which round tube swingarms would fit a 1978 K frame. I got a late model '77 or '78 CB550F swingarm that fits the mounting width, but has an offset that the CB750 arm doesn't have. With my 1978 wheel and spacers, the wheel is shifted way off center. I'm thinking that's the difference in motors maybe? Anyways. I'm looking for the info on what arms fit. I'm also looking to use eye to eye shocks so if it's a Suzuki or Kawi arm that'd work too.
Offline Mr Freeze
Re: Round tube swingarms that fit the CB750K
« Reply #1 on: June 06, 2016, 09:51:52 PM »
Anyone?
« Reply #2 on: June 07, 2016, 01:54:10 AM »
probably not many have done it as the the cb750 arm is actually one of the best of the '70's jap bikes once the bushings are sorted
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: June 07, 2016, 03:41:35 AM »
Doesn't the 79' DOHC come pretty close?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #4 on: June 07, 2016, 04:00:38 AM »
I think Lucky adapted 79 DOHC arm to SOHC frame.  From what I remember, he had to narrow it - not much - to fit in the frame.
Offline Mr Freeze
« Reply #5 on: June 07, 2016, 06:28:27 PM »
Thing about the spacer thing is that with an offset swingarm such as the 550. It makes the wheel sit way over to the right if you are sighting the bike from the rear. I'd want measurements of a 79 DOHC swingarm before I looked for a new one so I know what I need to do to make it fit.
« Reply #6 on: June 07, 2016, 07:15:49 PM »
Just curious...what is it about a round tube swingarm that you want?
Offline Mr Freeze
« Reply #7 on: June 07, 2016, 07:33:59 PM »
I'm doing more of a swingarm chop thing with this current project and I think a round tube swingarm looks better with what I'm going for. Right now the 77 CB550F swingarm is on there, but the offset makes the wheel very off center.
« Reply #8 on: June 07, 2016, 07:38:37 PM »
Ok, I get it now. :D  Tried centering the wheel with axle spacers then do what needs to be done to line up sprockets?
Offline Mr Freeze
« Reply #9 on: June 07, 2016, 07:46:06 PM »
So I paired the 750 rear axle and spacers with the 550 swingarm and because the swingarm is offset, the wheel is shifted off the center line as a result.
Offline Mr Freeze
« Reply #10 on: June 07, 2016, 07:51:47 PM »
See this is a '79 DOHC CB750 swingarm and already the forks look more symmetrical compared to a 550 arm.
CB750 DOHC
CB550 that's on there now.
If someone can verify that the DOHC swingarm will work with an SOHC frame ( I can shorten the width if neccessary) then my next question is bronze bushings for a DOHC swingarm and does the SOHC pivot fit. Need dimensions if possible.
« Last Edit: June 07, 2016, 07:56:01 PM by Mr Freeze »
Offline WaleFab
« Reply #11 on: June 07, 2016, 10:34:37 PM »
I made my swing arm bushings and looked for my drawings as to the OD and shoulder thickness/dia but cant recall / find them..., but I know that the ID for the CB750 is 14mm which really is all that would matter in regards to if the shaft would fit. Could buy a OEM for the 8$ or whatever they are and measure them for the OD for the press fit...
Compare the widths of the pivot tubes that goes between the frame. If need be, get some custom swing arm bushings made up with either thinner or thicker shoulders to fit between the frame (keep in mind dust seals have to go on aswell)
Its a good time replace or install a grease nipple aswell...
Side note... do the drop out slots and axle size for wheel being used correspond?
Modern mind / classic heart
'78 CB750 Cafe Mono / GSXR build
Offline BPellerine
« Reply #12 on: June 08, 2016, 06:37:26 PM »
the longer side of the pivot tube has to be trimmed to make the dohc arm fit,then it is a straight forward swap.bill
1978 CB 750K ard and webers
another anfob
Offline Mr Freeze
« Reply #13 on: June 09, 2016, 12:12:41 PM »
That's the answer I was looking for. Thanks!
Offline Nipet1974
« Reply #14 on: February 06, 2017, 10:34:14 PM »
hi,Nipet1974 here!!i bought a 1981 cb750c DOHC swingarm for my cb750 k2 as i wanted the extended look.can you please help me out and tell me if i need to trim the pivot tube only on the right side or at both sides and if so why in every occasion and what to do exactly with thd inner bushings and seals to make it fit my frame??i would really appreciate it!! I could use the mm measurements but i guess i can work with inches too!!thank you guys!!!!
Offline todd.s.holloway
    • 1975 Honda CB750F
« Reply #15 on: April 26, 2021, 11:26:14 AM »
CB750 DOHC
What was the outcome to this? Did you use the DOHC swingarm?
I’m currently trying to make a 550 swingarm work on my 1975 cb750, with the same offset to the right issue you had. Is the only answer to get a new swingarm?
I know some big name bike builders have used the 550 swingarm on a 750
« Reply #16 on: April 27, 2021, 04:17:34 AM »
I am running the DOHC 750 swingarm on my dragbike. Had to trim the tube at the pivot but don't remember how much. I seem to think I may have trimmed a little off both sides with most of the trimming being done to the long side, on the right (brake) side. Also, the DOHC 750 swingarm is about 1-1/2" to 2" longer than the SOHC 750 swingarm which will lean the shocks over a little more making the rear sit just a little lower with the same shocks.
Big name? Like, more than four syllables?  :o
TAMTF...
Wilbur
Projects:
