So I have 1975 Honda CB750F super sport with clutch issues.
It slips during hard shifting or fast take offs. I've also noticed in 5th gear doing 90 it slips. Hard throttle when passing.etc....
The bike does have extra weight but no more than a 200 lbs rider and 40lbs panniers when loaded.
I did change to new heavy duty springs, clutch and soak them over night in cycle oil.
I did not change the clutch plates but they seem clean and fine.
So the clutch has been adjusted correctly I suspect since I've adjusted a couple times with different pull points and tried different adjustments so the lever1/4 inch play before it engages and disengages.
I'm also using castrol 4t motorcycle oil 10-40w honda recommended oil.
I'm not sure if I have heavy springs with ebay replacement clutch plates. It was advertised as so but who really knows.
So does the CB750 generally slips on hard throttle and shifts? Is this typical since the cb750 is such a heavy bike?
Does anyone have a link to a set of good replacement plates, springs and clutch plates worth replacing at a budget.
I'm not a racer but I do like take bike out shift through the gear without slipping.
