Support the site. Your contributions keep this site running.
The 650 pump is significantly larger, I seem to remember nearly 20%. The outer cover is steel so holes are not countersunk.
Maybe not, I'll have to check in the morning. I didn't know there was a correct placement for it.
How do I assemble the kickstart to prevent the gears from meshing?
Got the kick start shaft assembled. Here is the solution.http://forums.sohc4.net/index.php/topic,161750.0.htmlThanks for the base gasket Dave.
