Author Topic: 78 CB 550K motor rebuild  (Read 60909 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: May 27, 2016, 10:28:21 PM »
Alright I'm starting this thread mid-stride. I didn't plan on rebuilding the engine (nor have I ever) this year but an unexpected stripped spark plug thread let me to taking off my head. I figured if I am going to do that I might as well make performance improvements and once you got one thing apart.... well you know how that goes.
In addition to hunting other threads, I would also like to call on the senior members ;) ;) ;D of the forum to assist in reassembly when the time comes.
Here is what has been done and where I'm at the moment.
-Thread was fixed with an insert by a machine shop
-Block+head were decked flat for an MLS gasket.
-Cylinders were bored to 553cc for 59mm Wisecos
-Jugs were treated with thermal dissipative coating
-Wisecos were shot with thermal reflective coating on the domes and treated with dry film lubricant on the skirts. (Thanks to calj737)
-Head was ported by Mike Reick
-Kibblewhite valve train: exhaust guides, valve springs,+1mm intake valves and exhaust valves.
-Serdi valve job
-Bored intake seats
-Megacycle 126-00 cam
-Hardweld rockers
-slotted cam sprocket
-Heavy duty cylinder studs (not yet installed)
The entire engine is being blasted and painted except for the block and bottom end covers. During this time I would like help in ordering any parts which sit in the cases that would need replacement such as primary chain, gears, oil seals etc...
Here are some photos of the current state of some of the parts sitting in the cases. I know you can't see everything from every angle but all the gears, sprockets anything with teeth on it looks good.
Yes that is the rear lower engine mount I didn't want to put it in vise and my cases are gone.
Can I use metal rescue on this rotor to remove rust?
I'm a little lost with some of these parts and looking at CMSNL isn't always clear.
Offline Camrector
Re: 78 CB 550K motor rebuild
« Reply #1 on: May 27, 2016, 11:19:08 PM »
I'll be following along, as I am doing a full rebuild myself. It's under "cb550 motor build" here on the forum.
Offline Bootsey
« Reply #2 on: May 28, 2016, 02:50:33 AM »
Should be quite the motor once you finish. Might be an idea to get some plastigauge so you can check the crank & rod bearing clearances.
Are you planning on replacing the primary chain & cam chain whilst you're at it?
Online calj737
  • I refuse...
« Reply #3 on: May 28, 2016, 03:07:17 AM »
Alek - Do this ^^^. In addition, contact member Elan and order an Oil Pump rebuild kit, get a new Oil Pressure switch, and replace all the oil seals on the cases. It's a small amount of money but worlds of value.
You can dip that rotor in Metal Rescue safely.
I imagine you will have lots of folks following along on this one  :D
Offline DaveBarbier
« Reply #4 on: May 28, 2016, 05:11:00 AM »
Nice! I didn't know you were doing all that work to the motor. That'll be really nice when you get it back together.
Also, this keeps crashing my Tapatalk! Probably don't need to upload pictures with military grade pixel density. Somewhere between potato and lab grade works.
Get OEM seals. The seal plug by the front sprocket is almost impossible to find, I'll see if I can locate one for you. I think it's #39 in the CMSNL parts fiche.
Edit: CMSNL says they have it. All other places I've looked the part says obsolete or unavailable. I had such a hard time finding mine I'll urge you to get this sooner rather than later. http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/oil-seal-34x9_91207374000/#.V0mLfPT3bCQ
Offline AlekStooge
« Reply #5 on: May 28, 2016, 05:52:33 AM »
Camrector: Welcome! I'll probably learn something from your thread.
Plastigauge, I've been seeing that a lot lately. I already have feeler gauges but I'll get those too.
I did plan on replacing the primary chain but seeing how much it costs I am kinda on the fence. I turned 10K on the bike shortly after I got it, not sure if it is necessary but then again since the cases are apart... Cam chain I'll replace.
Yeah I am pretty sure that oil pump will need rebuilt after I most likely got water in to it trying wash the cases of oil before shipping. :-[ Mike Reick already reamed me for this.
Yeah and that work is a done now painting and reassembly. We have to make sure it is carefully put back together. Don't want any valves breaking!
You showed me how to post pics using Imgur I wouldn't know why they look screwed up.
That seal looked to be in good condition an seems to be just pressed in...would I be able to reuse it? Where did you order your oil seals from again? Wasn't it a little here and there?
Offline DaveBarbier
« Reply #6 on: May 28, 2016, 06:20:36 AM »
Plastigage is a wax filament to check tight tolerances like crank bearings by how much is squishes. Something that needs to be done to see if you need new bearings.
I'm against using old seals because they don't have the squish anymore. I don't think these were pressed in at factory. I haven't heard of anyone successfully replacing that seal while the cases are together. Could be wrong though.
Yeah, it was here and there to get all OEM stuff. Took a bit of searching but it was worth it.
« Reply #7 on: May 28, 2016, 06:54:21 AM »
Alek,
With all that you have invested into the engine, do not cheap out on replacing the seals and the primary and cam chains.  They are not that expensive in comparison to what you have paid for other upgraded parts.  Remember, you are upping the performance/stress on the motor.  Do not create a "weak" link.
Love what I see so far.
« Reply #8 on: May 28, 2016, 07:14:26 AM »
The same is true for the 750 too, right? I want to grab the 750 version if it's available.
It you have to order from CMSNL, you want to make it worth your while (shipping is ultra pricey), so pick up whatever unobtainium items you may need.
Online calj737
  • I refuse...
« Reply #9 on: May 28, 2016, 07:41:03 AM »
Plastiguage is cheap insurance, but I'd be very surprised if after only 10k that the bearings need service. Primary chain, replace it or I'm coming to kick your butt  >:(
Offline AlekStooge
« Reply #10 on: May 28, 2016, 05:45:43 PM »
Dave: Check on the Plastigauge http://www.amazon.com/JEGS-Performance-Products-80593-Plastigauge/dp/B007VR8VFQ
I will get my hands on that one oil seal. I don't blame you for not remembering all those sources. I will be looking at David Silver, Cycle X, 4into1 etc... If anyone knows any good sources please share that would be much appreciated.
CB 750 Café Racer Fan: I agree I want to do things right because it would be a damn shame not to and re-disassembling is drag.
Cal: Cam and primary chain check
Doing some research and shopping tonight.
Offline DaveBarbier
« Reply #11 on: May 28, 2016, 07:01:36 PM »
Too much for the plastigage. The different colors distinguish different tolerances. You only need the green one. Any auto parts place will have it. Should be under $4. One strip will do.
I mainly use Partzilla (love hate relationship with them), David Silver and then typing 'Honda and then the part number' into eBay. Make sure the hyphens are in and in the right place.
CMSNL is great too but as Don said the shipping kills you. I just ordered two pilot jets from them and it's like $30 shipping, but they seem to have the best stock.
Offline AlekStooge
« Reply #12 on: May 28, 2016, 07:43:47 PM »
Sounds good on the plastigauge! I've never ordered anything from CMSNL I mainly have used it as a schematic and want to keep it that way.
How does the clutch look everybody? Plates appear to have rust on them.
Online calj737
  • I refuse...
« Reply #13 on: May 29, 2016, 04:28:30 AM »
Take apart the clutch basket and write down sequence of disc/plates, and pay attention to the orientation of things. Using calipers, measure each disc/plate at several locations around the disc for wear indicators.
If you plan on keeping them, set the friction discs in an oil bath and set them aside. The plates you can soak with Metal Rescue or MMO to remove any rust. Wipe after with Acetone, then into the oil bath with the discs.
Offline AlekStooge
« Reply #14 on: May 29, 2016, 11:36:05 PM »
Is this the complete oil seal kit?
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/oil-seal-kitcb550k_90000374000/
David Silver has most of these individually. I am cross referencing the manufacture codes to see if they are available and then hopefully save money on shipping.
Offline DaveBarbier
« Reply #15 on: May 30, 2016, 05:08:13 AM »
This isn't the complete kit. It doesn't come with one of the crank seals. And I'm not even sure it's actually OEM. It says "manufactured to Japanese quality control standards"
You could email and ask.
Offline AlekStooge
« Reply #16 on: May 30, 2016, 06:14:03 AM »
Ok, but at least that is all but one missing right? That way I'll at least know what I'm looking for. As I mentioned I wouldn't be ordering from CMSNL most likely because of their shipping costs.
Any more oil seals at any other part of the engine I'll need? I have a complete gasket set (I forgot what brand) but that might have some in there. I'll check that out when I have some time.
Offline DaveBarbier
« Reply #17 on: May 30, 2016, 06:48:28 AM »
It says it has 7 seals, but I don't remember if that's it for the bottom end. There might be more. It's honestly just research and cross checking part numbers, not very glamorous :).
Your gasket set probably doesn't have the rubber pucks over the head nuts. I haven't come across a gasket set that does.
Sorry I can't be much help on how many or what seals you need. I didn't save all that info. I do remember that as I was assembling I was ordering more seals that I forgot.
Offline separatist
« Reply #18 on: May 30, 2016, 09:05:03 AM »
Holy sh!t, the grail! I thought it lost forever!
Sent from my SM-G900T using Tapatalk
Offline AlekStooge
« Reply #19 on: May 30, 2016, 11:07:17 AM »
No worries, thanks.
Offline AlekStooge
« Reply #20 on: August 03, 2016, 05:32:40 PM »
Hi y'all
I haven't been working on the motor for a while. I had some family visiting and had to wait for the engine come back from painting.
I am ready to order seals some OEM seals. I got a little bit confused using CMSNL to find the Honda part number.They list the same part in the same schematic several times but they have different part numbers? I know certain parts are used several times in different places of the engine but having what appears to be the same part in the same spot listed several times with different part numbers does not make sense.
For example: Number 21 in the shift schematic. http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/E++16.html#results
I will look for the OEM part elsewhere just using CMSNL to get part numbers.
Offline AlekStooge
« Reply #21 on: August 06, 2016, 11:18:23 PM »
I figured out how CMSNL works a little bit better and I crossed referenced all gaskets, O-rings, seals and pucks with my cycle X complete gasket set. I found there was a total of 30 pieces missing and I made a list of those pieces not in the set.
I'm not understanding what a complete gasket set is if there is so much missing? It seems whether it's a Vesrah, Cycle X or NE brand they all have 55 pieces as part of a complete set.
Online calj737
  • I refuse...
« Reply #22 on: August 07, 2016, 05:08:44 AM »
O-rings and seals are not part of a gasket set, unfortunately. You'll have to do as you are, pick them piece by piece and buy them separately. Also, member Elan, sells and oil pump rebuild kit that has the very rare O-ring needed. Might encourage you to look him up and order that in as well too.
Offline AlekStooge
« Reply #23 on: August 07, 2016, 12:19:02 PM »
So that's what everyone does order them one by one? I'll look Elan up.
Online calj737
  • I refuse...
« Reply #24 on: August 07, 2016, 12:53:31 PM »
Only way I know of... >:(
