Author Topic: 1981 CB650 Custom Front Forks  (Read 2534 times)
Offline pmanning
« on: May 29, 2016, 05:45:45 PM »
My son wrecked his '81 650 about a month ago bending both fork tubes and breaking the axle bore on the right fork leg.  He bought what he thought was a replacement front end off ebay but when we tried to fit it up today we discovered a major difference. His original fork tubes were 35 mm whereas the used ones he bought are 37 mm.  Before the wreck he'd also bought a fancy billet aluminum top triple tree clamp that he wants to reuse.  My hope is that we can get the tube bores on the clamps machined to accept the larger tubes.  The worry side of me wonders if that will leave sufficient metal in the clamps to provide adequate strength.  I'd like to know if anyone has tried this and I'd welcome any thoughts.
Offline mrfish2
  • I might be a
Re: 1981 CB650 Custom Front Forks
« Reply #1 on: May 29, 2016, 07:02:21 PM »
I've got a set of forks from an '82 650 nighthawk if you'd rather have another set instead of messing with all the machine work required to make your new forks fit.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline grcamna2
« Reply #2 on: May 29, 2016, 07:42:58 PM »
2mm doesn't sound like that much to remove from those strong triples;what does your custom top triple look like? pics ?
« Reply #3 on: May 29, 2016, 08:01:35 PM »
That means 40 thou off each side, should be OK, But is the SPACING and OFFSET the same on the other fork, good chance its different.
 I cant see a 650 fork being real pricy..
Offline cb650
« Reply #4 on: May 29, 2016, 08:30:17 PM »
They probably sent you 82 nitehawk forks that are bigger.    There are 3 diff sizes on the sohc4 650's and spacing.
Offline pmanning
« Reply #5 on: May 29, 2016, 09:23:23 PM »
We got the bottom triple tree with the used forks but not the top clamp.  The spacing is different on the on the bottom clamp of the replacement forks we bought compared to the original geometry on the '81.
The billet aluminum top clamp that we want to reuse is a Dime City Cycle product; http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-steering-parts-billet-aluminum-cb650-top-triple-tree-12-2147.html.
There is a very good machine shop locally that I trust to do the work.  My only concern is that the somewhat thinned clamps will be sufficiently strong.
« Reply #6 on: May 29, 2016, 09:55:19 PM »
 That is a bit thin, but the top gets less force into it,
 BUT..... if any of your dimensions, like width are different, you are screwed......
Offline grcamna2
« Reply #7 on: May 29, 2016, 10:36:13 PM »
That billet top triple is thin and already 'bare to the bone' in those areas,I wouldn't bore that one out,get a matching oem Honda top triple for what you already have.
Offline mrfish2
  • I might be a
« Reply #8 on: May 30, 2016, 05:46:53 AM »
Interesting, I didn't know that. Guess he doesn't need mine then!
1980 CB650C - Sold
« Reply #9 on: May 30, 2016, 08:55:01 AM »
I think the later nighthawk fork are 37mm and might have different spacing and offset.
It sounds like it would be easier to just find another front if you are set on using the DCC top triple.
Offline pmanning
« Reply #10 on: May 30, 2016, 03:47:18 PM »
Thanks all for the input.  I think we will put aside the option of machining the clamps to accept the larger tubes.
So we are now in the market for an '81 front end if anyone has one available and we have and '82 Nighthawk front with legs, tubes and bottom triple tree if anyone is interested.
« Reply #11 on: May 30, 2016, 04:24:20 PM »
I have one but it is 400 miles away in cold storage.  I kept the chassis rolling to make it easier to move around.
« Last Edit: May 30, 2016, 04:26:14 PM by CB750 Cafe Racer Fan »
« Reply #12 on: May 30, 2016, 04:27:19 PM »
Try member tomwitt
He frequently parts out 650s.
Offline Flatlander80
« Reply #13 on: June 01, 2016, 09:17:03 PM »
I have a set of forks off a 1980 CB 650 Custom. They are from a parts bike, but that bike was running a few years ago. If you're interested, PM me.
Sent from my iPad using Tapatalk
« Last Edit: June 01, 2016, 09:19:00 PM by Flatlander80 »
Offline 74cb750
« Reply #14 on: June 02, 2016, 07:13:16 PM »
I also have a set of forks, air controled?
 see here:
http://www185.pair.com/canukvt/hon/
and
http://www185.pair.com/canukvt/hon/1983_cb650sc/
remember, there is often a lot of difference amoung the CB650c/CB650SC/CB650
make sure you measure and have the seller verify all dimentions you can....just saying.
michel
Laugh at least once a day.
Life  $ucks, then you die.
