Author Topic: Got one! '76 CB400f - Lots of new pics  (Read 1754 times)
Offline Rob_D
« on: May 30, 2016, 05:52:36 PM »
I'm not a new member, but I might be considered new new that I have a SOHC/4 to go along with my 350 twin (that is now in boxes).
I've been trolling for on of these for a while...so I worked quickly to pick up this '76.  I like the yellow...so that is a bonus.  Seller seems to be an honest bloke.
  • 30,000 miles
  • $1500 US
  • It runs - sounds good to me
  • Shifts through all gears
  • All lights work
  • No sheared cam adjustment bolt
  • some dents in the tank - but the tank interior is spotless
  • Non original mirrors...and the seat seems to be missing the chrome rivets
  • silly looking wind screen
Here's a link to the cache'd ad that has taken down.  http://webcache.googleusercontent.com/search?q=cache:61JZ8cC5zi4J:www.kijiji.ca/v-sport-bikes/kitchener-waterloo/honda-super-sport-cb400/1169185394+&cd=1&hl=en&ct=clnk&gl=ca
I tried to attach some photos from the ad.  I'll add some more when I pick it up.
« Last Edit: June 05, 2016, 10:29:11 AM by Rob_D »
76 CB400F - Survivor
68 CL350 - Working on a complete re-do
17 Moto Guzzi V7III Anniversario
Offline Rob_D
Re: Got one! '76 CB400f
« Reply #1 on: June 02, 2016, 06:24:53 PM »
Geez...thought you guys would be at least a little excited.   ;)
Oh well...I am.  I'll get her home and see what it needs to get he back on the road.
« Reply #2 on: June 02, 2016, 06:34:36 PM »
Nice CB400F ! looks very unmolested.I hope you enjoy it  :)
Offline Rob_D
« Reply #3 on: June 02, 2016, 06:46:30 PM »
Yessir...I've been looking for one of these for a while.  Didn't think I'd find one for a reasonable buck in Canada.
I plan to just ride this one while I work on my '68 CB350 project.  That's the plan anyway.
I'll post better pics when I get her home and attempt to clean it up a bit.
« Reply #4 on: June 02, 2016, 07:29:13 PM »
Yes,a few more pics  :)
Offline Rob_D
« Reply #5 on: June 05, 2016, 10:28:51 AM »
As promised - more pics.  Here is a link to the video of startup.  https://www.youtube.com/watch?v=1HGZpOqinNM
I welcome any comments form keen observers of this bike.  The seat looks to be missing the grommets, and the mirrors are not correct.  Not sure about everything else.
Re: Got one! '76 CB400f - Lots of new pics
« Reply #6 on: June 05, 2016, 10:56:41 AM »
Nice pics Rob,  8)
What are your plans for this 400F ?
Offline MoMo
  • Ride like you're invisible
« Reply #7 on: June 05, 2016, 12:24:34 PM »
Looks good, it is possible the lower fork caps are on backwards,  Hard to tell from the photos but the part of the bottom cap that is lower goes to the rear of  the bike.  In other words the gap should be in the back. Welcome...Larry
Offline Rob_D
« Reply #8 on: June 05, 2016, 05:45:16 PM »
My plans are to get it certified for the road (been off the road for a few years)...and ride it grcamna2.
I've got a '68 350 Twin project I can work on in the meanwhile - it is in boxes.  Once the 350 is done, then maybe I'll re-do the 400f.
I just came back from a short ride.  Observations:
  • It seems to run just fine.
  • The clutch does take a lot of effort...and grabs right at the end.  I have adjusted it...it seems right at the end of adjustment. Maybe I need a new cable.
  • Seem to go up the gears well
  • I have not revved it past 5000 - no problems getting there at all.
  • The headlight is quite faint - not sure if it's this particular bike.
  • No smoke.
  • Exhaust does smell rich - but, again, it seems to run fine.
Offline Rob_D
« Reply #9 on: June 05, 2016, 06:14:35 PM »
Thanks MoMo.  Sharp eyes - I think you're right.  I looked for the pre-load adjustment...and didn't see it.  Maybe that's why!
« Reply #10 on: June 05, 2016, 08:32:53 PM »
I think Larry/MoMo may be referring to the bottom hold-down 'half-clamps' that hold-down the front axle,they need to have the closed part facing forward and the 'gaps' facing toward the rear of the bike,then you can accurately tighten them down to the correct factory torque.Check your oem Honda factory shop manual for removing and installing the front wheel.
Offline MoMo
« Reply #11 on: June 05, 2016, 08:34:11 PM »
exactly right
« Reply #12 on: June 05, 2016, 09:20:32 PM »
Why not?  Isnt the redline 10,000??
Life BEGINS at 5K!!
Offline MoMo
« Reply #13 on: June 06, 2016, 03:25:16 AM »
Life BEGINS at 5K!!
plus there isn't any power below 5K
Offline Rob_D
« Reply #14 on: June 06, 2016, 04:00:50 PM »
Life BEGINS at 5K!!
Ha ha.  I figure I shouldn't go there until I've had a chance to go through the valve train...and adjust the cam chain.
I'll have to do a little research on here on the cam chain bolt - I did know they broke easily...but I'm not sure why that is the case.
Offline MoMo
« Reply #15 on: June 06, 2016, 04:13:49 PM »
Rust and people then try to ham fist them out without deruster or heat.  Plus, I broke one whilst removing the motor from the  frame
Offline Rob_D
« Reply #16 on: August 29, 2016, 02:12:39 PM »
Here she is after a LOT of cleaning.  I don't think it had been cleaned since 1980.
She runs well - a little flat spot at 4000...but good other than that.  A rich mixture was addressed with a new air cleaner that had been in there for 10 years I'd bet.
She's a little loud with a "tap-tap-tap" sound...but I have not yet made it to the valves.
« Reply #17 on: August 29, 2016, 03:14:42 PM »
She looks nice  8) after the good cleaning you gave her Rob.
