Author Topic: CB500 charging questions  (Read 346 times)
Offline stevenmgrr
« on: May 31, 2016, 12:08:31 PM »
Forgive my lack of knowledge regarding electrical, but I'm trying to learn.  My bike isn't charging.  Rev test on fully charged battery yields a maximum of 13.5 volts (even above 4000 rpm).  So, I've tested the stator (1.0-1.9 between each of the yellow wires, no continuity to ground) and the field coil (5.5 between white and green wires, with no continuity to ground).    While the posts that I read have stated that it is rare that stators go bad without physical damage to the case (I haven't had any), based on these measurements would this indicate that my stator is bad?  What further tests do I need to do?
Steven M
'71 CB500 K0
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=0j4s16p9sic48b2mk45jo1kbc2&/topic,60973.0.html
Re: CB500 charging questions
« Reply #1 on: May 31, 2016, 12:31:38 PM »
try to pover up the vhite and  green( vire and see if it gives autput at the yellow vires.
.or even at the battery
i hate all this v-w.... vords
Offline b52bombardier1
« Reply #2 on: May 31, 2016, 01:44:38 PM »
Run the same test above that you did for DC volts but flip the multimeter knob to AC volts.  What do you see?
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
