Author Topic: LED license plate bolts — recommendations?  (Read 684 times)
Offline SKTP
« on: June 02, 2016, 03:02:15 PM »
I had a pair of LED license plate bolt that burned out in under 400 miles...similar to these
http://www.amazon.com/Rupse-White-Motorcycle-License-Plate/dp/B008RIEQXY?ie=UTF8&dpID=41Tk53IAozL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=M65A0288RCPB5P5D2EQJ&ref_=pd_sim_263_4
Actually for $6.50 those might be the next ones I try...but I was wondering if anyone has a brand of these that they have had success with?
Those one specifically say "no resistors are required" I wonder if that was the issue with my set?
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: LED license plate bolts — recommendations?
« Reply #1 on: June 02, 2016, 03:06:36 PM »
 Do you use two or four, I could make a set that look like rockets with the plate between the 2 halfs. They wont light up though. There is a pic of them in a sale under new brake adjuster.
« Last Edit: June 02, 2016, 04:06:24 PM by 754 »
Offline SKTP
« Reply #2 on: June 02, 2016, 03:07:47 PM »
I just use 2...then one....now zero
I'm hoping to just do these on the cheap...
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #3 on: June 02, 2016, 04:06:40 PM »
yes I know that...that is why I am asking
I do not want custom made ones, just good working lights
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
