Author Topic: Why you don't use silicone sealers  (Read 3683 times)
Offline Bill/BentON Racing
    • BentON Racing
« on: June 04, 2016, 11:01:29 AM »
Just thought y'all would like to see!
BentON Racing Website
BentON Racing Facebook
Offline CycleRanger
  • No comment about being an
Re: Why you don't use silicone sealers
« Reply #1 on: June 04, 2016, 11:10:09 AM »
Horrors!  What a noob. Didn't even use red hi-temp.  ;D ::)
(That is a joke btw, before someone thinks I'm serious..)  ;)
Offline kmb69
« Reply #2 on: June 04, 2016, 11:21:54 AM »
I just love those cute little stalagmites on the outside oil passages!  ;D  ;D  ;)
« Reply #3 on: June 04, 2016, 11:30:56 AM »
 I use it without problems..
 Should be titled People need to look up the meaning of SPARINGLY, and THIN smear...
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: June 04, 2016, 11:49:21 AM »
I'm with you Frank. Its all I use except in case of MLS gaskets of course. I seldom have leaks. I use grey rtv, rigid. I won't use anything else. I've seen many racers get pushed off the dragstrip by track officials because of oil leaks. I can't afford to drive 7 hours to a race and not be able to get down the track because if my negligence. Up
But hey, to each his own.
Offline teebee67
« Reply #5 on: June 04, 2016, 11:52:48 AM »
I use it too and have done for nearly 30 years on my race engines. Like most things, if it's done right, it's fine.
I'm only old on the outside.
Offline CycleRanger
« Reply #6 on: June 04, 2016, 11:59:45 AM »
I think Bills point is they actually make sealers for those pucks that is superior to clear silicone bathtub sealer in any quantity....
    • BentON Racing
« Reply #7 on: June 04, 2016, 12:06:27 PM »
Eggsackley, I use Honda RTV, yes point was what happens with excess! And I damn sure don't use the old blue sh×t!  Honda's seals and hass no offensive smell also.
« Reply #8 on: June 05, 2016, 11:04:32 AM »
What about the blue Hylomar under and around the edge of the rubber pucks? "Manufactured under licence from Rolls-Royce"
Offline koendd
« Reply #9 on: June 05, 2016, 12:25:01 PM »
I've used hylomar for the pucks on 2 engines with no problems ;)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline mrbreeze
  • Not your average
« Reply #10 on: June 05, 2016, 03:46:39 PM »
I'm doing mine soon. Right now I've got almost all of the old paint off the cases so I can paint. The cam is out so after painting....I'm ready to install the pucks. I believe it was Edward Morris that said he used Permatex #2 and had no problems. I planned to remove any excess after leaving it to set up. What about the O-rings at the oil nozzles and the end passages. Should they be left dry or a dab of something to hold them in place? I also picked up a tube of the high temp thread sealer for the tower studs. I will reread Brandon's thread before I dig in.....I've probably read it at least 5 times already!
I just planned on using the #2 instead of the Hylomar sealer unless someone knows of a reason I shouldn't.
MEMBER # 257
Offline Old Scrambler
« Reply #11 on: June 06, 2016, 06:00:47 AM »
Nice example, Bill ;)
I use #2 on the pucks..........nothing on the o-rings or oil-jets.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #12 on: June 06, 2016, 08:47:07 AM »
I have used it too since late 80's (got it free at my job) . Before that GOLDEN HERMETITE that was really good, worked fine sealing cases too.
Offline Haybus
« Reply #13 on: June 06, 2016, 09:37:41 PM »
https://www.aircraftspruce.com/pages/ep/lubricants/ezturnlube.php
Put it on both sides of every gasket and you'll never need to buy another gasket. It's like really sticky Vaseline.
Alan
75 CB750
76 KZ900
« Reply #14 on: June 08, 2016, 03:19:16 AM »
Alan
I searched for a seller in Europe by just pic search in google. EZ TURN LUBRICANT
Found this:
https://www.amazon.com/Cinnamon-Desensitizing-Anal-Eaze-Lubricant/dp/B00XPSYXUW?ie=UTF8&*Version*=1&*entries*=0
Maybe ok too?
Offline Restoration Fan
  • My wife will never call me
« Reply #15 on: June 08, 2016, 04:04:53 AM »
Found this:
Maybe ok too?
Just be careful.  The Hot Cinnamon flavoring is probably good for an extra HP or two, don't you think?  :o
Offline Haybus
« Reply #16 on: June 08, 2016, 06:42:23 PM »
I did the same thing. Took a couple days for Amazon to stop showing me inappropriate purchase suggestions  >:(
Alan
75 CB750
76 KZ900
Offline mrbreeze
  • Not your average
« Reply #17 on: June 08, 2016, 11:07:14 PM »
The EZ turn sounds interesting (the gasket one!) but I already have a tube of Permatex 80060 high tack gasket sealant. My plan is to stick it only to the cover side and a light smear of assembly lube to the case side.
I painted my cases yesterday so I'm getting closer to putting things back together. Still have to do some touch up and cover polishing. I don't care anymore about the time consuming task of polishing....it's so worth the effort! Here's a couple of pics.
MEMBER # 257
« Reply #18 on: June 09, 2016, 07:49:56 AM »
The EZ Turn seems to be a good thing to have in the garage. Probably useful in many applications.
« Reply #19 on: July 12, 2016, 09:39:22 PM »
 I bought a 477" big block chevy that had the blue silicone overhaul kit, the oil pump was even full of it. It can even wreck a big block.
