Author Topic: Kick-start spring?  (Read 469 times)
Offline separatist
Kick-start spring?
« on: June 05, 2016, 11:24:22 AM »
Assembling my crankcase today and can't seem to figure out how the kick-start spring sits. This seems way loose, obviously. Bad spring, or do I have to wrap it full around to pre load it?
Sent from my SM-G900T using Tapatalk
Offline Tews19
  • I am no
Re: Kick-start spring?
« Reply #1 on: June 05, 2016, 11:29:08 AM »
It's not on. See the left on left side of case. Attaches there
1970 Honda CB750 survivor.
Offline drumstyx
« Reply #2 on: June 05, 2016, 12:09:09 PM »
Hondaman's book says there are several CB750's that have his blood on them because of that spring. As I recall it is indeed quite a bit preloaded. I don't remember where it mounts, but I do have pictures of every linkage during disassembly somewhere....
Offline separatist
« Reply #3 on: June 05, 2016, 12:22:21 PM »
Sorry, but huh? Not sure what you're saying. There's a lip on the spindle that one side attaches to - I'm assuming that right angle on the spring sits on the crankcase where that ledge sticks out?
Offline edwardmorris
  • Youngish
« Reply #4 on: June 05, 2016, 12:55:49 PM »
I cheated and compressed it in my bench vise, then tied it up using some wire, installed, then snapped and pulled out the wire.
Not sure if this is much help, but the best pic I could find from my old build, this is how it looks assembled
« Last Edit: June 05, 2016, 12:59:34 PM by edwardmorris »
