Author Topic: 1978 Honda CB550k  (Read 1499 times)
Offline Onelesscar83
1978 Honda CB550k
« on: June 06, 2016, 10:40:18 AM »
So, this is my first post and hopefully not my last.  Since March, I have been rebuilding a 1978 Honda CB550k.  This is my first build of this extent and has been a HELL of a ride.  So much fun, agony, learning, processing, failure, and success.
You can see all the pictures here
https://briankillmore.smugmug.com/1978-CB550K-REBUILD/
starting point was decent with a bit of a cafe racer look, but EVERYTHING was barely attached/working.  What I've done so far:
rebuilt/cleaned carbs and replaced all jets/seals/most screws/pod filters
cut and welded frame to flatten the back end
rebuilt wiring harness, previous owner extended the wires but nothing was soldered together.  Everything was just twisted and tapped......it was a mess.
built box to hold all the wiring, and replaced the reg/rec unit with new combo unit.
new firestone tires, new seat from tuffside
new signals and tail lights
redid ALL connection points on the bike.  they were ALL corroded to the point of no return.
modified rear fender
rebuilt master cylinder and front caliper
rebuilt fuse box and found places to hide wiring harness components
cleaned up connections at the coils with new bullet connections
added mac 4 into 1 exhaust- not shown in pictures yet
I'm currently stuck on the charging system.  Just doesn't want to work for me.  I replaced the original rusted out one with a used stator that was supposedly working when it left their junk yard.  From what I've read they are pretty hard to destroy, but according to the manual the 3 yellow wires from the stator should have a 3.5 ohm resistance between each pair.  I'm getting 1.9 on each pair.  Does that mean the stator I bought as a replacement is also shot?  Are there replacement parts I can find NEW?
Re: 1978 Honda CB550k
« Reply #1 on: June 06, 2016, 03:21:38 PM »
Not a fan of Firestone tires, but welcome Brian.
I am not sure if you need new electronics but if you do (you might want to hit up Cal Jeffrey on the forum), you can get new parts: http://ricksmotorsportelectrics.com/
« Reply #2 on: June 07, 2016, 07:45:35 AM »
This being my first build I'm flying by the seat of my pants.  To be honest I had close to no experience with engines and or motorcycles besides the little tw200, I messed with before this.  So I'm sure to mess up a bunch of things.  As for the firestones what do you guys dislike about them?
The harness wiring would have been close to $60 to get all the colors I needed to extend the harness that had been chopped up by the previous owner.  25ft of black was $6, so budget won there. I made sure to keep sections on either side of the splice that were of the correct color.  I wasn't in love with my decision to add all black wires, but my pockets were empty.  On a plus side they are all soldered and heat shrunk now instead of twisted together and black electrical tapped.....it was a disaster in there.
moving forward to make SURE everything is right I went out and bought a second multimeter.....$5 from harbor freight....nbd....the other one i have was close to $50 so we get both ends of the spectrum
                               mm1           mm2
No key               = 12.86v  and 12.87v
key                    = 12.46v  and 12.47v
idle (1500rpm)  = 12.46v  and 12.47
3000rpm           = 12.47v  and 12.48
5000rpm           = 12.47v  and 12.48
yellow wire combos from stator in ohms
mm1=    1.1  1.1  1.1
mm2=    1.4  1.4  1.4
spec should be 3.5.....I'm thinking this stator is also shot.....
green to yellow wires in reg/rec
mm1     -to green + to yellow      5.03     5.24      5.4
            +to green - to yellow         .483     .478      .5
mm2    -to green + to yellow         no readings
           +to green - to yellow          no readings
Only other thought I have is the Dyna S ignition is sucking all my power?  I have read a bunch of not so great things about these things, but it came with the bike and is an expensive upgrade so I wasn't going to complain.
« Reply #3 on: June 07, 2016, 08:45:29 AM »
I doubt it's your Dyna S.  There have been some issues with the Dyna 2000, but the S is pretty reliable.
« Reply #4 on: June 07, 2016, 12:33:59 PM »
Oh none taken just explaining my thinking and situation.
According to the tests on this fault finding diagram my battery is shot.....its brand new.....I went through everything twice.....I guess I'll take it back and try again?
Its NOT your DYNA.
Try using this diagram to troubleshoot your charging system:
http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
And I completely understand about budget building and wire colors.  ;) No offense intended. You did all the important things well, like solder and heat shrink those connections.
« Reply #5 on: June 07, 2016, 06:08:45 PM »
So I took the battery to Advanced auto and had it tested.  Battery is good.  I went through and double checked the ground and sanded the CRAP OUT of every connection and they are all clean....no changes....
What next?  I'm so at a loss here.  I was debating replacing the starter solenoid cause it looks pretty beat up....
« Reply #6 on: June 07, 2016, 07:14:29 PM »
Yeah I replaced both the reg/rec with a combo unit, and all the bullet connections/block connections on the entire bike.
« Reply #7 on: June 08, 2016, 05:53:25 AM »
If you want to come by that would be AMAZING.  I'm about as stuck as I can be.
I wonder if you have possibly crossed up a wire from the stator to your "new" harness. Got any detailed shots of your Reg/Rec connections? By the way, I am heading to Statesville today. I'm happy to bust a bit farther down and drop in and see if I can identify the issue. It would need to be early afternoon, but if that's of interest, let me know.
« Reply #8 on: June 09, 2016, 07:50:41 AM »
Ok, latest update.  After about 3 and a half hours with calj737 we decided the reg/rec is at fault, even though the diodes were in spec......fingers crossed there as I already ordered a new part.  Also as we were messing with things the seal behind my drive sprocket started leaking, so add that to the parts list.
While waiting on those parts I think I need to tackle these wheels.  The previous owner decided plastidip would be a good fix for everything on the bike, including both rims and all the spokes.  The rear wheel is pretty untrue and has a big hop in it.  I tried taking it to be trued but no one will touch it with the plastidip on there.
Here are my options:
1) replace both wheels.....suggestions on what would fit with minimal work/money even if they are used.  I love the mag wheels just not sure if there is a swap out option for the 550k?
2) pull both wheels apart clean the plastidip off and rebuild.....WAYYYYYY out of my comfort zone/ have no idea what I'm doing here.  Youtube could most likely help and A TON of labor.   Plus either buying a truing stand or building one.....from wood?  not sure about that either.....I'd also have to re-finish the rims.....sounds expensive.
Basically looking for the cheapest option here, thats not going to look like a disaster....
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: June 09, 2016, 10:10:23 AM »
Period Lester wheels, like the ones on my bike in my profile picture, area a direct bolt up. But they are fairly rare and generally expensive. Yamaha and Kawasaki both had Lester style wheels on some of their bikes that come in the right size, but you would need to fab up adapters.
