Author Topic: Front brake line Single or double flare? degree? Anyone know?  (Read 645 times)
Offline J.Webster Designs
  • www.JWebsterDesigns.com
Hey guys,
Just wondering if anyone knows the specifics of the front steel brake line going into the front caliper. I do not have an original line that I can take a look at.
Need to know if the original front steel line is a single or double flare and what degree the flare is.
Any help would be appreciated!
Cheers!
Justin
VISIT OUR WEBSITE!
FOLLOW US ON SOCIAL MEDIA!
Facebook:
www.facebook.com/JWebsterDesigns
Instagram:
www.instagram.com/j.websterdesigns
Offline slikwilli420
  • Master of Disaster
Re: Front brake line Single or double flare? degree? Anyone know?
« Reply #1 on: June 06, 2016, 11:39:09 AM »
I've done some investigating on different flares and applications. I seem to recall a double flare for our lines, since they were 45 degree flares. The double flare is used when there is no backing piece (like a tube sleeve) for added strength. Now that so much is -AN flares, which are 37 degrees, we need to be careful not to mix and match without the right adapter. Because the 37 degree -AN flare uses a tube sleeve under the nut, there is no need for a double flare.
« Reply #2 on: June 06, 2016, 01:32:31 PM »
So original CB750 front hard lines were 45 degree double flare? Anyone else confirm this?
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: June 06, 2016, 05:10:54 PM »
"Japanese Inverted Flare" is what Russell calls it.
Their item 641471 is an adapter from this to AN-3:
At one point, I made up a custom hard line by using SAE tubing, transferring the fittings from an old stock hardline, and flaring it with a standard flaring tool (45 degrees?).  It sealed up fine and I ran that line for many years.
So, somewhere pretty close to 45 degrees  ;)
mystic_1
- John Augustus Shedd
« Reply #4 on: June 07, 2016, 06:12:04 PM »
Thanks Slik and Mystic for the info!
VISIT OUR WEBSITE!
Facebook:
Instagram:
Offline GritCity750
  • 5th time's a charm!
« Reply #5 on: June 07, 2016, 08:36:03 PM »
I double flared (45 degree) my stainless hardlines and they turned out dead-on to the original ones
