Rotate the crank until the point opens to its widest on the 1/4 point. Set the gap to .35mm.
Turn the crank just past this point so the point begins to close. insert the .35mm gauge
While holding and gently tugging on the gauge, rotate the crank around again, the feeler should slip out with the same resistance as when you First set the gap. If it comes out easier, stop here....re-set the gap to .35mm again, and repeat ^
once set, complete ^^^ for the 2/3 gap
Its easy to perfectly set the points gaps with a dwell meter... once the bike is running.
