http://forums.sohc4.net/index.php?topic=157550.125I posted a bunch of pics of how I mounted mine in the 5th (?) Page of the above thread.
The oil cooler type, dimensions, and mount location ideally needs to be coordinated with the damper mount and position. I have taken MANY reference photos of vintage racers at race events and found that the overwhelming majority run the NHK type or something similar.
I am using a modern Ducati 1100 oil cooler on mine. I chose it specifically for both the appearance (it looks very much like a 5 row version of the old CR750 3 row coolers, and the design allows me to BARELY fit the oil lines past the damper mount(top side of the cooler). I mean it's tight. I went out of my way to create a very clean appearance (an unnecessary personal issue).
I had to make custom fittings for the an10 lines to work out the way I wanted it. I don't recommend my specific path, unless you enjoy the punishment.
![Shocked :o](http://forums.sohc4.net/Smileys/default/shocked.gif)
I wanted the damper setup to allow FULL travel side to side if desired, not something you need for road racing only. But it would be best if you have positive stops on the steering head that bottom out before the damper reaches the end of its stroke on either end. It's a bit of geometry gymnastics, again check my photos for an example. Mockups with cardboard and zip ties, checking clearances with the trees swinging both ways. I chose the left hand side for the damper for no other reason that it will be more natural for me to keep my right hand on the throttle while adjusting the damper with my left hand on the fly if desired. Otherwise, it doesn't seen to matter.
FWIW, NONE of my stuff is tested, never mind battle tested, so take that off what is worth. Theory only
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
I'm sure others will chime in shortly.
George
