Making progress on the chassis. I was going to wait until the engine was done then slide the bare frame over it for easy installation, but time is running too short and I know that as I assemble things will need to be fitted and massaged so I started there first. The frame assembly is in a really good spot, with the swingarm pivot (new grade 5 Titanium with Ti nuts) fitted to frame and arm and swinger shimmed perfectly for smooth pivoting but no side-to-side play. Shocks are fitted (need some adjusting) along with new swingarm bobbins.
The front has been assembled, waiting to be put back on the bike, with neck bearings greased and bearing nuts snugged up appropriately. Wiring is also back on the bike except coils and ready for action. I was running into space issues on the brake handle bar where I wasn't able to fit everything on the bar AND get good position on the brake lever with 2 fingers. I realized Woodcraft does bars that are 11" instead of 12" so I swapped both sides out for 12" bars and now can get 2 finger braking further out on the lever which should help with hand fatigue and increase brake pressure. I also had some looseness of the bolts in the holes for both the caliper lugs on the fork and the holes in caliper so made up some very thin spacers for the bolts which take up all of the gap and now with the bolts even finger tight, there is no movement in the caliper at all.
The wheels are still in progress and have not been trued, but are laced and the front is pretty close but needs more truing and final tightening of spokes.
Pistons should have shipped last week to Kenny at Cycle X and I should have an update from him this week on progress. I sent a vapor blasted cylinder to him provided by member Ekpent so he has everything he needs. The cylinder will be bored with torque plates, honed, decked, and have the rings fitted before coming back. Once back with me, it will get the m6 holes on top fitted with Timeserts and APR 6pt bolts, as well as have the windage window slots cut in the sleeves between 1-2 and 3-4.
A little side project (not that I really have time, but, ya know) was to build a heat shield for my carbs. With the heat of the engine able to enter the intake tract so easily especially with open filters and the engine making more power, it seemed like something that was worth the effort. I used some 0.080" Kydex (popular for pistol holsters) which is a thermoform plastic that is very chemical resistant. I cut everything to shape to fit around the carb insulators and other items (cam chain tensioner). It turned out really well, looks race and should be function to some extent.
Still to do:
- Finish wiring install (coils, kill switch)
- True wheels, install tubes/tires, balance
- Fit rear master cylinder and plumb brake line
- Mount seat and tank (tank getting some mounting changes)
- Engine top end assembly and cam degreeing
19 days until track day, 31 until first race...
