Author Topic: Cam Sprockets  (Read 1616 times)
Offline Big Jay
    • CBRzone
Cam Sprockets
« on: June 16, 2016, 01:26:13 PM »
Fresh batch of adjustable cam sprockets right out of black oxide ready to package up.
Re: Cam Sprockets
« Reply #1 on: June 16, 2016, 10:14:00 PM »
Jeez,  looks like a hundred run.
Are they bobbed or teeth cut on a CNC mill?
Offline Big Jay
    • CBRzone
Re: Cam Sprockets
« Reply #2 on: June 22, 2016, 02:53:10 PM »
Gang hobbed.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Cam Sprockets
« Reply #3 on: June 29, 2016, 12:11:49 PM »
I am interested in adjustable cam sprockets.
But what is the advantage aside from easier install?
Offline Bill/BentON Racing
    • BentON Racing
Re: Cam Sprockets
« Reply #4 on: June 29, 2016, 12:36:52 PM »
Bro,  lots, there's some excellent articles on cam timing and what it can and does do! Jay may have some on his site, most cam companies have instructions,  I'd say Google cam timing for SOHC 750 Honda's.  G'luck,  Bill
BentON Racing Website
BentON Racing Facebook
Re: Cam Sprockets
« Reply #5 on: June 29, 2016, 01:03:41 PM »
Adjust the cam correctly. You can advance the cam 3-5 degrees to get mor torque at low, or opposite to get more power at top.
Or just time the cam according to its spec. Std sprocket will most likely not give correct setting.
 Good bolts and threadlocker. Suzuki bolts have nice wide heads (for old GSX1100 and other models from the 80's),
http://www.ebay.com/itm/321660960468?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
others like Yamaha bolts
There are good descriptions to find on Internet in general or on these forums.
Satanicmechanic has information to fully understand - http://satanicmechanic.org/cams.shtml
Below prints of the papers I got with my Action Fours cam.
Measure cam with 0 valve lash, tightened adj screw until the dial indicator needle stert to move - This to measure cam and compare with cam data
Measure open, close numbers at a certain lift, 0.004" or 0.005" (1mm or 1.25mm)
Then measure with running lash to get a better picture about how it will be for real.
I understood the last part fully when timing my last cam, DP315 that has recommened lash of .012"  (0.3mm), double or tripple compared with other cams
Cam was made for that lash, it opened very early and closed very late with 0 lash or running smaller lash. Overlap was huge as well. Cam showed its correct persona with the lash it was designed for. Open/close, duration like other cams, but lift not that high.
« Last Edit: June 29, 2016, 01:11:25 PM by PeWe »
