Author Topic: RE: CB750 Sandcast head 0?  (Read 831 times)
Offline chewbacca5000
  • I polish covers!
« on: June 18, 2016, 09:16:03 AM »
While fixing my leaky pucks I noticed that my head had the drilled oil passageways and 0 stamped on the head.  Could my head be Sandcast head 0?
Pretty excited!  I know this bike makes tons of power.
Re: RE: CB750 Sandcast head 0?
« Reply #1 on: June 18, 2016, 09:38:26 AM »
Does it have the front Centre bolt in front of 2/3plugs ?
  • I polish covers!
« Reply #2 on: June 18, 2016, 10:25:30 AM »
Is this the pic you need?
  • I polish covers!
« Reply #3 on: June 18, 2016, 10:28:00 AM »
I am dying here.  Is this Sandcast 0?
« Reply #4 on: June 18, 2016, 10:40:31 AM »
Look an inch higher is there a bolt in the middle or not.
Sandcast heads are not numbered on a per bike basis.
  • I polish covers!
« Reply #5 on: June 18, 2016, 11:17:06 AM »
No bolt.  Is it a sandcast?  What is with the zero stamped in there?
« Reply #6 on: June 18, 2016, 11:48:25 AM »
It's 26,*** or lower. Someone may be able to narrow it down more.. What number are the cases?
  • I polish covers!
« Reply #7 on: June 18, 2016, 12:06:57 PM »
Cases are k1.  Crank appears to have been lightened as you can see where the big chunk on the end of the alternator was removed.
  • I polish covers!
« Reply #8 on: June 18, 2016, 12:07:44 PM »
Thanks Frank!  You mean 2,600 or lower?
« Reply #9 on: June 18, 2016, 02:40:09 PM »
Nope there's 26 thousand heads with the missing bolt hole,and cylinders to match
I am pretty sure early heads have differences, but not sure how to tell .
Now if the valve cover looked a lot different. Underneath, like graph paper or a waffle...I would suspect  early..
  • I polish covers!
« Reply #10 on: June 18, 2016, 07:45:15 PM »
Trying to account for all the power this engine makes, and maybe the head is part of the deal.  The cam did not have the typical R# stamped into it like honda cams so.
It has a raised circle with F on it.  Any ideas what that would mean?
« Reply #11 on: June 18, 2016, 07:47:59 PM »
Does it have any rings around it?
Offline kmb69
« Reply #12 on: June 18, 2016, 07:53:29 PM »
Those heads, early carbs, and early exhaust made noticeably more power IMHO.
