Author Topic: Throttle slide to bore distance adjustment - CB400F  (Read 579 times)
Offline Robbbiee
« on: June 26, 2016, 10:50:29 AM »
Trying to set this distance per Haynes manual (0.040")
When I open throttle to full, the slides go wayyyyy past tops of bores and I cannot find the 'full throttle opening screw' that the manual mentions in order to adjust?
Any help greatly appreciated,
Rob
Offline robvangulik
  • Honda Fourever
Re: Throttle slide to bore distance adjustment - CB400F
« Reply #1 on: June 26, 2016, 03:37:45 PM »
You are looking inside the carbs, while you should look on the 'butterfly'where the cables are attached.
Distance between screw and butterfly (C) should be max about 2,0 to 2,1 millimetre.
« Last Edit: June 26, 2016, 03:42:56 PM by robvangulik »
Offline Robbbiee
« Reply #2 on: June 27, 2016, 03:02:39 PM »
Ty, but I found it - hiding at the back just in front of the return spring.
