Author Topic: 75' CB400F front end swap  (Read 3000 times)
Offline x_O
    • 6MillionStories: The portfolio of Dereck Larsen
« on: June 27, 2016, 06:18:17 PM »
So I recently purchased this front end from a 93 CBR600F2:
A quick background, I'm new to motorcycles but I feel I'm learning pretty quickly. My aim with this is to build it up over the summer and put it onto my 1975 CB400F.
My questions:
Shock Rebuild: Since they're used and I don't know their history I plan to do a rebuild on the shocks. Seals and all that. Maybe even some Race Tech emulators if I'm feeling fancy.. Can anyone recommend any good websites, or youtube videos for how to do this on these shocks? I can't imagine it's too hard but I'd love a guide to follow for peace of mind.
General: At my purchases current state, what are all the things I'll be required to get to make this install happen? I assume to I'll need to get the obvious new head tube bearings, brakes, rotors, cables, speedo system (Don't know much about these) lever, rim, and tire. Am I missing anything?
Wheel: I don't really care for the look of the mag wheels and want to keep to rims... I've seen people talk about using Harley rims, so I'm curious if there's a certain kind that works best for the dual disc brakes? Also, What would need to be done to the hub for it to be ready for the dual disc?
I think that should take care of my questions, any insight into the project a head is greatly appreciated.
Dereck
« Last Edit: June 27, 2016, 06:58:20 PM by x_O »
Offline Bodi
Re: 75' CB400F front end swap
« Reply #1 on: June 27, 2016, 07:33:07 PM »
There are a few things to look at:
Steering stem diameter - same as the stock one? Tough to fit if it isn't.
Steering stem length - this can be changed but not easily.
Triple tree offset: this distance, plus the rake angle (set by the frame) and wheel trail (varies with wheel diameter and axle offset, if any) sets the steering geometry. This is critical, bad geometry can be unpleasant to ride... or seriously dangerous to ride. My stock CB77 has to be deliberately forced to turn, my old stock RD400 was super twitchy by comparison. The 400F stock setup is very neutral, easy to turn and quite stable.
I don't know the 600F2 rake, unlikely it's the same as a 400F. The triple offset is unlikely to match either.
There are folks who have done it, and you should check with them what they did and if the bike was rideable with the swap.
Offline x_O
« Reply #2 on: June 27, 2016, 09:53:13 PM »
Bodi,
Thanks for the reply. I still start looking into those things. I got this fork based off this build:
http://www.dotheton.com/forum/index.php?topic=28160.0 since it didn't sound like there was too much work involved. However, in the write up nothing was too descriptive.
« Reply #3 on: June 27, 2016, 10:04:50 PM »
You may have to build a new stem.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: June 28, 2016, 04:07:33 PM »
Damnit Cal I was about to mention the cognito moto conversion trees.
Offline x_O
« Reply #5 on: June 28, 2016, 04:24:18 PM »
Thanks for the heads up on the AllBalls process.
I got in contact with the guy from the blog build and what he had to say about the process in more detail was this:
"I had a 400 stem pressed in to the 600 lower triple. The diameters are the same, so it's an easy swap. I measured the axle to top clamp measurement of the 400 forks, and made sure the 600s were set to the same length. They are longer, so stick up a bit above the clip-ons. You might see I have a 400 hub, into which I've fitted a couple of disk rotors with adapters I had made. The bearings to fit the 600 axle fit straight in to the 400 hub. Inner diameter is larger from memory. I had to weld some steering stops on the bottom of the steering stem to engage with the stops on the triple clamp."
Being that I'm new to motorcycles I don't fully understand everything that's being talked about. I'm starting to research it all as it comes up though.
What I do understand so far is that I need to measure the axel to to top clamp and match the height, and that some adapters need to be fabed up, (I asked if he would make me some for a price) or spend $$$ on the Cognito hubs. New wheel bearings to fit 600 axel. The AllBalls headset bearings. And that something will need to be welded to engage the stops on the lower triple tree so the clipons don't smash the tank. and lastly that I won't need the emulators but to look into some progressive front springs. Each piece going on this setup will be rebuild also.
As far as pressing the stem into the 600 lower triple, I don't follow. TBH I don't know what the stem is? Is it the bar that connects the upper and lower triple tree's together? What is offset when in this context? Would the use of the steering damper be needed on my bike if I don't plan on bringing it to the track?
To answer your last 2 questions I would rather use a digital speedo, and I'm using the old bar controls since this is going to be alarge enough project for now haha.
Offline slikwilli420
  • Master of Disaster
« Reply #6 on: June 28, 2016, 07:55:24 PM »
If you are going to do trees and want to save a bit of coin I have a bunch of designs I can do in a variety of thicknesses with custom dimensions like offset and fork spread. My signature has more details or feel free to shoot me a PM.
  • Holy Cow! I'm a
« Reply #7 on: June 28, 2016, 07:58:51 PM »
Hey x_O
Can we call you wink?
« Reply #8 on: June 28, 2016, 08:12:46 PM »
Is your lower tree steel, theory stock 400 stem is welded into the lower tree.
 There is maybe ways around the welding.
