Author Topic: Is there a side stand switch that locks out the starter?  (Read 3748 times)
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« on: June 29, 2016, 07:50:03 PM »
1971 Honda CB750
A couple times now I have hit the starter button with my bike in gear and the kickstand down only to have it lurch forward!  :o  Is there a switch available that will lock out the starter when the kickstand is down?  I don't want a neutral switch as it might be necessary to start the bike at a light after stalling.  I am specifically looking for a way to lock it out when the side stand is down.
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
Offline nicks2319
  • Youngstown, OH
Re: Is there a side stand switch that locks out the starter?
« Reply #1 on: June 29, 2016, 07:56:51 PM »
You could rig up a universal brake light switch and make it work probably.
But i'd spend less time thinking up a way to rig this and more time figuring out why the bike is stalling at a stop.
Offline CycleRanger
  • No comment about being an
« Reply #2 on: June 29, 2016, 09:33:28 PM »
Is there no clutch interlock on a K1?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: June 29, 2016, 09:37:39 PM »
Perhaps it was bypassed?
Did that to a neutral safety on my bombardier.  Because trying to get a bike into neutral whilst stuck on the open face of a dune is sketchy.
« Reply #4 on: June 29, 2016, 09:41:25 PM »
Perhaps you can adapt a modern kickstand switch to your neutral interlock.
Offline Davez134
« Reply #5 on: June 29, 2016, 10:43:43 PM »
I'm pretty sure there isn't. Not on either of my k2's.
« Reply #6 on: June 29, 2016, 11:32:04 PM »
Long time ago I had a cheap one. It was a little container with mercury and it was easy to attach to the sidestand. It didn't work long and on inspection after some weeks I discovered all mercury had leaked away. Still I think every bike should have one (not the mecury one). Why they never made that a law instead of wasting good mirrors with texts, remains a mystery to me.
« Reply #7 on: June 30, 2016, 04:43:48 AM »
Think those rolled in around 1974.
Offline ksmith0034
« Reply #8 on: June 30, 2016, 04:48:37 AM »
I was really hoping someone had done this already.  I'm not an electrical engineer so I don't know if I can make something on my own or not
« Reply #9 on: June 30, 2016, 05:07:41 AM »
So was I, as I sometimes forget to retract my sidestand which is dangerous. I often wonder why there's so little ingenuity here. A fine exception I remember is Flybox (http://forums.sohc4.net/index.php/topic,158068.msg1813037.html#msg1813037)
« Last Edit: June 30, 2016, 05:10:20 AM by Deltarider »
Offline calj737
  • I refuse...
« Reply #10 on: June 30, 2016, 05:09:23 AM »
1971 Honda CB750
Pardon me, but you have it all backwards. If you need to re-start at a light, then you definitely would benefit form a Neutral Safety Switch. A side stand switch would only benefit you in the garage, but a NSS would be effective in ALL circumstances. If you stall, the first thing you'd want to do is pull the clutch before you hit the starter. This insures you're either in Neutral, or the clutch is disengaged so you don't go lunging forward into a stopped vehicle.
I get the whole side stand idea, but its my opinion they are not terribly effective and they're prone to problems. When you drive away with the side stand down, momentum or friction will often pop it up anyway. But, vibration can cause it to move away from the frame just enough to disconnect your electrics and cause intermittent stalling.
So I'd wire in a NSS from a later year and be done with it. My opinion.
Offline calj737
  • I refuse...
« Reply #11 on: June 30, 2016, 05:10:44 AM »
The stock unit on later models is prone to the very failure I mention above, is why more people don't add them but instead remove them. Even Hondaman will tell you they were problematic.
« Reply #12 on: June 30, 2016, 05:18:51 AM »
Don't I know it, but it's the way this happens. I had some narrow escapes and I remember in particular departing from quite close to a steep canyon in France where I had paused to make a picture. Scared the wits out of me. It's for this reason models for Germany had to have this special rubber tip (see various parts lists).
Offline dusterdude
« Reply #13 on: June 30, 2016, 05:22:02 AM »
No
Sent from my LG-D850 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #14 on: June 30, 2016, 05:26:11 AM »
If you pull the clutch in and try to start and it lurches forward, the problem is your clutch is not fully disengaging. It may need to be cleaned, replaced, adjusted, do the HondaMan extra lube trick, etc.  Sidestand switches are a pain and the manufacturers went to them for liability purposes.
Offline CycleRanger
« Reply #15 on: June 30, 2016, 06:01:38 AM »
No
Well now I know.
The 750A has a sidestand switch, but no clutch! :)
Offline Dunk
« Reply #16 on: June 30, 2016, 06:19:47 AM »
Because government is evil and laws are oppressive, you may want to be careful what you wish for.  I prefer no such laws and a consumer driver market for factory and aftermarket equipment rather than a government driven market. A switch or lockout is easy enough to add if it concerns the individual. One of the reasons I stick with 60s or early 70s vehicles is to avoid absurd government laws and regulation.
In any event, I'd use a rear brake switch if it concerned me. Also I think the CB750A had some sort of sidestand switch. Maybe that would be a bolt on thing? Aside from that I'm surprised nobody has mentioned safe starting procedure... Always verify the trans is in neutral at least with the neutral light (though I usually rock it slightly forward and back to verify) and pull the clutch in when starting the engine. I also do not use the electric start, have only used it for a while while injured and able to ride again but unable to kick. Being on the bike while you start it gives you control of the situation if you have a brain fart.
« Reply #17 on: June 30, 2016, 06:57:04 AM »
Sorry that I broadened the subject somewhat with departing without retracting the sidestand first. Am I the only one that had it happen a couple of times? As far as silly government laws, I think everybody knows where I stand. Bringing on the headlight before you've started is about the stupidiest
« Reply #18 on: June 30, 2016, 08:56:33 AM »
Don't tell anybody Delta but I did it yesterday, keep it our little secret  ;)
« Reply #19 on: June 30, 2016, 10:43:07 AM »
Maybe we could use that silly blinker buzzer that everybody disconnects anyway. Bidding is open.
Offline CycleRanger
« Reply #20 on: June 30, 2016, 11:37:49 AM »
Just get a kickstand from a K5 or later that has the little rubber thingy on the end.
« Reply #21 on: June 30, 2016, 04:35:05 PM »
The little rubber kick up came out on K2.
But that's not an answer to the OP problem.
Offline ksmith0034
« Reply #22 on: July 01, 2016, 06:31:22 AM »
Correct, that is not what I'm asking about.  I am trying to find a way to lock out the starter when the side stand is down.  Period.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #23 on: July 01, 2016, 07:38:12 AM »
A normally open momentary contact switch mounted on the frame or kickstand bracket that is closed when the kickstand is raised. Wire it into the ground lead for the starter solenoid.
EZPZ
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline 01Thomas
« Reply #24 on: July 01, 2016, 02:11:38 PM »
No, that only came in later models.
