Author Topic: WHERE TO GET SMOOTH HANDLEBAR TOP CLAMP ?  (Read 3264 times)
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« on: November 21, 2006, 08:13:29 AM »
As the topic states, My buddy who is building the "starship" bike is in need for a smooth top handlebar clamp to replace the idiot light/dashboard.
I am comming up empty handed trying to find one, although I know I have seen them for sale somewhere on the net...
Anyone ?
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: WHERE TO GET SMOOTH HANDLEBAR TOP CLAMP ?
« Reply #1 on: November 21, 2006, 08:18:51 AM »
There's a thread on here somewhere about these...
checking.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
    • TVAM
« Reply #2 on: November 21, 2006, 08:26:38 AM »
I think it's Chippy550 although the pictures in his gallery are not really clear.
Ask him!
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Geeto67
  • A grumpy
« Reply #3 on: November 21, 2006, 10:16:08 AM »
Contact Lowrider Tommy (LRT) on the Honda chopper board. I think he has his own set he sells that are flat:
http://www.lowridersbysummers.com/parts/index.htm
Otherwise you cut and polish a stock one (and tig in the holes).
edit: oops, thought you wanted the whole top clamp, not just the part that goes around the handlebar. Try using the 750F claps. They are two seperate pieces but no idiot lights and will polish up really nice.
« Last Edit: November 21, 2006, 10:20:36 AM by Geeto67 »
Maintenance Matters Most
Offline mkramer1121
« Reply #4 on: November 21, 2006, 10:49:00 AM »
Hey PT, tell him to exhange the front end with that of a GL1000.  Under $200 to swap, you get larger, better forks, and a smooth clamp.  I'll send ya pics when I get my parts back from powdercoating.
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #5 on: November 21, 2006, 11:08:15 AM »
as many inquires as I have had, I should open my own store ;)!!    ..or put it in the FAQ'S??
here it is....
DRAG specialties " part #DS-290650 handlebar clamp fits 75-83 GL"
is what is on my 500/550.
http://www.sohc4.us/gallery/v/members/personal/chippyFive50/
http://www.cyclepages.com/ProductGroupDisp.aspx?ProductGroupID=4000959
I just GOOGLED it.  I don't know if this is the cheapest place....
« Last Edit: November 21, 2006, 07:40:53 PM by chippyfive50 »
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline ProTeal55
  • Est1968.com
« Reply #6 on: November 21, 2006, 12:15:47 PM »
He isnt running a GL frontend - he is running the stock CB750 deal - so I take it the above mentioned clamps wont work/fit ?
Offline Chris Liston
    • http://christopherliston.com
« Reply #7 on: November 21, 2006, 12:37:33 PM »
I think chippy said he IS running the GL clamp on his 550.  The clamps should be the same because there is probably a minimum width that the bars need to be safely clamped.
2008 Triumph Speed Triple Black and NASTY
1976 CB550F Cafe in progress
http://gallery.sohc4.net/main.php?g2_itemId=2402
Offline ProTeal55
  • Est1968.com
« Reply #8 on: November 21, 2006, 12:59:07 PM »
10-4
Offline jevfro
  • 1975 CB750 K5
« Reply #9 on: November 21, 2006, 02:16:01 PM »
I believe there was an early year that had all the idiot lights in the guages and the handle bar clamps were just two smooth caps.  On one of carpys builds he ordered some from Honda
Offline Geeto67
  • A grumpy
« Reply #10 on: November 21, 2006, 03:32:59 PM »
I think it is the K0's. F0-F2 they are two smooth caps also as the idiot lights are between the gauges. The early Police cb750s used a cb77 style headlight and had smooth clamps also.
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #11 on: November 21, 2006, 07:45:44 PM »
It bolted right onto my 71'  500, and my 74' 750 looks the same...it is not a "PRECISION" fit (For $12)  but it has worked fine for 2 years now.. I had the 4 idiot lights on my stock clamp..
SOHC Member#4000
78' 550
73' CL175
Offline STLrocker
  • whiskey bent and hell bound
« Reply #12 on: November 21, 2006, 08:43:17 PM »
if you want a one piece, the one chippy has would be the way to go, i guess.
if you want the two seprate ones, like mentioned for the f models, you can make them from the original clamp you have. if you look at the underside of the clamp, you will see that if you cut the middle section out, it will leave you two seprate caps shaped just like the F ones.
 if you are good with a grinder and file, it wont look like something you just hacked up. it will look identical to the stock pieces. just cut, grind, file, and polish. quick, easy, and, best of all - free. did it on mine before i went to clip ons.
Offline Matt Hubbell
Offline dusterdude
« Reply #14 on: November 22, 2006, 09:29:10 AM »
man,those things are cool
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #15 on: November 28, 2006, 05:56:21 AM »
Found out a couple guys have tried to order this clamp and they are saying its been discontinued. DAM!
Offline ProTeal55
  • Est1968.com
« Reply #17 on: November 28, 2006, 07:43:30 AM »
MG Products. http://www.mginproducts.com/Honda%20CB750%201969-76%20Triple%20Tree.html
Will that fit the CB550.  Please say yes :)
Chippy has a 550 , and he is running a clamp simiar, so I am guessing it will fit your bike....
Offline Geeto67
  • A grumpy
« Reply #18 on: November 28, 2006, 12:24:05 PM »
The top clamp vonblond posted is different from what chippy is running as it is a whole top clamp. As far as I know it will not work with a 550 because the distance between the forks is different for a 550 than a 750. YOu may want to ask them if they can sell you a blamk one and have a local machine shop machine it to your 550's needs.
