Hi All,
I have a 1978 F3 Cb750 with 24,000 Miles on it. The engine turns over and all cylinders have 120 PSI cold compression test except for Cylinder #4 which is about 50 PSI. There is an audible “PFFFT” sound coming from somewhere near it when i have the compression tester hooked up but I can’t quite locate it by ear. What are the steps I should do before i take the Engine off the bike and try to rebuild. What easy things should I Check which could be causing this leak? Any pictures, videos, sound files that you guys might need please say so and I will post ASAP.
Bike Is currently almost 100% apart, Engine is sitting in frame but carbs and exhaust are currently off the bike.
Thanks!
Andy
