Author Topic: Stupid question  (Read 965 times)
Offline gbal06
Stupid question
« on: July 13, 2016, 06:29:40 PM »
I developed a oil leak around the "round" part of the engine and want to know what area that is so I can replace the gasket.  Is it the generator cover? Do I need to drain the oil before replacing it and what type of oil does everyone recommend?  Thanks
Online Stev-o
Re: Stupid question
« Reply #1 on: July 13, 2016, 07:18:47 PM »
Yes, that is the generator (or stator) cover.
Spectro is the best oil, Greg uses it and his bike has over 150,000 miles without a rebuild!
Offline gbal06
Re: Stupid question
« Reply #2 on: July 13, 2016, 08:42:47 PM »
Do I need to drain the oil before replacing it?
Offline flatlander
Re: Stupid question
« Reply #3 on: July 13, 2016, 10:24:59 PM »
if i put a shop manual next to my bike, will it learn to maintain itself?
« Last Edit: July 13, 2016, 10:28:39 PM by flatlander »
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
Re: Stupid question
« Reply #4 on: July 13, 2016, 11:32:32 PM »
only after downloading the app on I-phone 6 or later  ;D
CB750K6- survivor   CB500K2, CB550K2- projects
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Stupid question
« Reply #5 on: July 14, 2016, 12:21:49 AM »
The 550 stator does not reside in an oil bath.
If you are in fact leaking oil out the stator cover, gasketing the round cover is not the solution!
Far more likely culprits are oil galley plug/bolt oring below the stator.  Or the oil pump orings under the chain case cover.
Offline flatlander
Re: Stupid question
« Reply #6 on: July 14, 2016, 07:59:13 AM »
if you take off the covers off the left engine side, clean everything well, put some baby powder on and let the engine run a bit until the first traces of wet show on the powder, you should be able to locate the culprit fairly easily.
then there's no hope, i don't have such a fancy phone  :-[
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Stupid question
« Reply #7 on: July 14, 2016, 09:00:24 AM »
Has any of the covers been off to see exactly where the oil leak is coming from? Try that first. As Bomber said there is no oil gasket around the Alt Cover. If it is leaking from the drive chain cover, which is way more likely, these are easy fixes. A shifter seal, a primary drive seal, and three oil pump o-rings are all common sources of oil leaks. Find out then get back to us.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline gbal06
Re: Stupid question
« Reply #8 on: July 14, 2016, 09:21:32 AM »
will do, thanks
