Author Topic: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod  (Read 38566 times)
Re: 1978 CB750 - Re-born a 836cc Wiseco JMR Ported Hot Rod
« Reply #150 on: February 17, 2017, 06:36:14 AM »
Wow, Nils! Blown away again!
I just saw that Carpy is getting into vapor blasting. Although more local, I'd still send out to Nils given his track record of performance and customer service.
Offline slikwilli420
  • Master of Disaster
« Reply #151 on: February 17, 2017, 06:48:50 AM »
But Don, Carpy invented the cafe racer movement in America and we all owe him everything for that.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #152 on: February 17, 2017, 06:48:55 AM »
Customer Service is a lost art these days. For most things, I will happily pay more for good customer service!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline BLAC
  • An espresso is a
« Reply #153 on: February 17, 2017, 09:11:52 AM »
 ;D ;D
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #154 on: February 17, 2017, 09:33:27 AM »
Carpy invented vapor blasting. ;D
Offline Ericcb750
« Reply #155 on: February 17, 2017, 09:45:06 AM »
Nils has been the best Since I first contacted him about this project. He's always been helpful even creating and sending me a video about the "dykes" and removing my kickstarter pin....ha-ha.
Always quick to reply and encouraging, and the guys work is just absolutely flawless. I will recommend anyone to go to him, I can't wait to see those Koni's when they're done....with the aluminum bodies all vapor blasted and the black springs.... going to be sick.
I've never dealt with Carpy on anything., seems like he knows his stuff but alot of his stuff is just not my style.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline joeyvans
  • Definitely not a
« Reply #156 on: February 17, 2017, 10:05:18 AM »
As in, you don't wear a pompadour, rolled short sleeves and jeans?
1976 CB550 K2
Offline BLAC
  • An espresso is a
« Reply #157 on: February 17, 2017, 10:28:39 AM »
I just imagine Carpy walks around snapping his fingers asking people if they are Sharks or Jets.
« Last Edit: February 17, 2017, 11:47:29 AM by BLAC »
Offline Ericcb750
« Reply #158 on: February 17, 2017, 11:33:56 AM »
Alright so I do have a serious question for all you fellas...  For those of you who have taken a motor down this far, Did you replace any of the bearings on the main shaft/counter shaft? Or did you just inspect them, clean them a little bit and slap them back in?
Basically, i had a tough time getting to one of the counter shaft bearings (in the middle of the case), I didn't want to damage anything so Nils removed it with a bearing puller. He recommended getting a new one, which got me thinking...Should I be replacing those ? That's the only part of the engine that i haven't really thought about....
All the other parts that are going back in have been inspected and are perfect, And are these things still available?
Probably pretty expensive if so. But let me know for those of you that have done this.... THanks
1978 CB750K
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #159 on: February 17, 2017, 11:48:59 AM »
I don't know about the 750's but they were not expensive and I did buy new ones for my 550.
The stock ones seemed fine, but for the $20 or so I figured what the hell.
Offline Davez134
« Reply #160 on: February 17, 2017, 12:00:29 PM »
I reused mine as they seemed in perfect condition as far as I could tell. As stated its cheap enough insurance to replace them, but I personally did not have a need to.
« Reply #161 on: February 17, 2017, 12:04:59 PM »
Im debating this myself on a race motor I am doing. I am taking the slow burn on getting it done so I will probably do them, but I wans't originally planning on it. The full set for the 750 is almost $250 from CMSNL. One bearing is like $65 so its hard for me to swallow but in the grand scheme you probably won't even notice the money is gone.
Generally speaking for bearings, I have gathered that if they don't "click" when you spin them and they don't have excessive side play, you are good. Flush them out good and give this a spin in a quiet area and listen, if it sounds good, it probably is.
« Reply #162 on: February 17, 2017, 02:11:48 PM »
I reused mine, too.  With a 650 motor they are less readily available.
« Reply #163 on: February 17, 2017, 02:43:23 PM »
I have some new pins in stock ;D
« Reply #164 on: February 18, 2017, 01:42:07 AM »
Carpy invented Al Gore who invented the internet...ain't it great!!
;D ;D ;)
Offline Ericcb750
« Reply #165 on: February 21, 2017, 11:48:50 AM »
Christmas in February looks like it will be coming tomorrow!!!!  Looks like most of my goodies will be coming home . I'll post up some photos of the kaboodle when I get them.
What an awesome guy Nils has been to work with, Could not be happier with the way this stuff turned out.....and I haven't even seen it yet!!!!!
1978 CB750K
2005 Sportster 1208
« Reply #166 on: February 21, 2017, 11:52:23 AM »
You'll be tasting the rainbow of fruit flavor aka Skittles soon.  Post copious amounts of photos of the "caboodle."
Offline BLAC
  • An espresso is a
« Reply #167 on: February 21, 2017, 12:54:14 PM »
Im tasting the rainbow at my desk right now  8)
Offline Ruckus2115
« Reply #168 on: February 22, 2017, 08:10:30 AM »
Just wow with that cleaning.  Looks amazing.  I think I might need to send my stuff down to him as well. With the carbs did you send them down there whole and he broke them down? or did you break them down?
Excuse me for my dumb questions....but if you do plan to paint it or thermal coat the cases, heads, and jugs....do you do that prior to rebuilding everything?  Do you have the loose steps in your head for the rebuild?
for example..
get the parts back
get the cases painted/thermal coated
reassemble the cases
get the jugs bored and then painted?
rebuild the heads and then painted?
I am just curious as to what your overall steps are.  I am in a similar situation with breaking down a '76 750F.  Just trying to time everything right on my end
Thank you Calj737 for the thermal coating pics.  I would love to find someone local to me able to do this sort of process.  I really do not want to paint my engine...would rather have it powder coated or thermal coated...
Offline Ericcb750
« Reply #169 on: February 23, 2017, 03:32:26 AM »
Hey Ruckus,
   Glad you like the photos, and I got all my parts back last night.....They're 10x better in person, just absolutely amazing work on Nils' part....Super fast turn around time and he's been a Huge help along the way.
As far as the carbs, I tore them completely down when I sent out all the parts to him, so every part inside was broken down....as far as the linkage, I sent that and the choke linkage out there assembled.....There are some reasons you don't want to Completely dis-assemble the carb linkage (little stud in the rod, and something else that I can't remember. Theres really no reason to 100% break down the stay plate/linkage too. He cleaned that up as well and it's beautiful
I'm thinking after Cal's suggestion, to look into the thermal coating for my cylinders (maybe the head too). But as far as the cases, I'm going to run them for a while as they are....The finish is beautiful and with a little work (Cleaning and such) Nils has assured me they can be kept up very nicely. Maybe down the road if they're nasty (talking years from now) I'll have them cleaned up again or painted...
I have gone over the motor build 10 times already on all my assembly.....First step is going to be going through the cylinder stud holes with a "thread chaser/repair" tool per Nils' recommendation.... The threads are perfect as is but just to make sure as I'm going to be installing the APE HD studs and Main bearing Studs as well.
I have all the bearings for the rods and crank (which was balanced by Mike Rieck), so that will be sweet. I am going to look into getting new bearings for the trans while i'm in there.... The bearings that came out are literally perfect so I'm going to keep them for a future project....
Let me know if you have any questions on anything, I have 100% of the parts for the new motor (bolt kits, bearings, cam, tensioners, new HD Chains, etc) so I'm good to go.
There is an amazing thread on the forum by "BrandEn" about re-building a "leak free" top end , I would check it out as he has some awesome info/tips in there. Best of luck on the project. Give me a shout with Questions.
1978 CB750K
2005 Sportster 1208
Offline BLAC
  • An espresso is a
« Reply #171 on: February 24, 2017, 12:21:56 AM »
Tasting the rainbow at work at your desk!?  :D ;D
Offline Ericcb750
« Reply #172 on: February 28, 2017, 10:46:14 AM »
I'd taste that rainbow all day and night. Haha.  I know I'm slacking on the photos fellas,.. here's a few... id put these up in a cleanest set of cb750 carbs contest... I have all brand new internals for theses babies too fresh from Japan.... Honda needles and needle jets, mains - 120, pilots 40, float valves and seats, all new Honda rubbers, etc.
With the stay plate and choke linkage all cleaned up.... there will literally be brand new!!! Wohoo!
1978 CB750K
2005 Sportster 1208
Offline Ruckus2115
« Reply #173 on: March 01, 2017, 06:19:39 PM »
Carbs look beautiful. So I talked with a thermal coater locally and he said even if I did send parts to get vapor blasted that he would still want to clean them and prep them to take the thermal coating. Sounds like I do plan to thermal coat my cases, block, and head. Where'd you source your carb parts for the rebuild? I am shocked how good looking they are.
Offline Jnel
« Reply #174 on: March 02, 2017, 04:35:46 AM »
This stuff looks amazing.  He will get some business from me. Really ... i mean woooooo. 👍
Sent from my SAMSUNG-SM-G935A using Tapatalk
